Does anyone known if I can use ATMEGA32L-16PU clocked at 7.3728 mhz? In datasheet say that this type works at 16Mhz, can be used for this project? Or is imperative to use ATMEGA32L-8PU at 8Mhz.
Thank You!
Thank You!
