По серийнику точно 4 головы? Может, даунсайз
Так винт 2-х блиновый с 4-я головами,
По серийнику точно 4 головы? Может, даунсайз (MDW в терминах сигейта)?
P.S. Насчет тонок15 - ошибся, они вроде как 133 ГБ/блин стандартно, MDW - соответственно, меньше, около 100 ГБ/блин, судя по инфе из интернетов.
А по чем вы опознали что на первой голове много ошибок.
К примеру:
Zone 3 - 08e7a.1 Target = f (2)
  W/R Code - 43
Zone 3 - 08e9a.1 Target = f (2)
  W/R Code - 43
Zone 3 - 08eba.1 Target = f (2)
  W/R Code - 43
Zone 3 - 08eda.1 Target = f (2)
  W/R Code - 43
Zone 3 - 08efa.1 Target = f (2)
  W/R Retries Exceeded 43 ***
и
Clearance constants: Freq 01AD, RdClr 0.1529, Cyl 0212AC
Hd,Zn,WP,WrClr,WCScale,ClrWht,WpWht,BPIC,FBPIC,TPIC,FTPIC,Sat,Capcty
 1, F, 0,0.048,-0.104,0.904,0.9610,0.5994,0.5994,0.5784,0.5784,0.1927,0.3012 S P
 1, F, 1,0.059,0.053,0.954,0.9710,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 2,0.074,0.267,0.969,0.9790,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 3,0.084,0.409,0.984,0.9850,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 4,0.094,0.545,0.989,0.9900,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 5,0.103,0.675,0.994,0.9950,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 6,0.113,0.812,0.996,0.9975,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
 1, F, 7,0.117,0.867,0.998,1.0000,0.0000,0.0000,0.0000,0.0000,0.0000,0.0000
Fail: No saturation point found
Я примерно думаю вот что: я треки взял от 250 (ST3250624A) гигового винта для 200 гигового, может быть он поэтому хочет из моего делать 250-ку ?
Возможно. Поиграйтесь с HDW/MDW (4>cx)
ST3200827A
  • Залить апп, стартонуть его, после - с T>
  • Фууух..... NiTr0 спасибо, ошибку свою понял. Исправил скрипт,
  • Вы винту говорите, что кормить его будете
  • Вобщем попытался загрузить АПП таким скриптом SPEED/115200/b0115 SLEEP/4000/1 STR/d60,1/0 SLEEP/4000/1 SEND_FILE/512/app.trc/<0/<238 SLEEP/4000/1 SPEED/9600/b0096 В итоге написало,
  • Если тест все-таки пройдет, посмотрите по 2>x какой
  • Tomset После того как ввел F>j1..22
  • Вот скрипт заливки церт таблиц SPEED/115200/b0115 SLEEP/4000/1 STR/h15/0 SLEEP/4000/1 SEND_FILE/512/TBL.trc/<0/<15 SLEEP/4000/1 SPEED/9600/b0096 Правильный ?
  • Tomset Вполне вас понимаю, только мне
  • ещё апп надо будет записывать ,если просто N2,,22
  • Во-во! представляете какие мозги у ремонтников которые их
  • Значит так, вродебы правильно. Заливаю (апп,церт+церттаблицы) Заливаю app SPEED/115200/b0115 SLEEP/4000/1 STR/d60,1/0 SLEEP/4000/1 SEND_FILE/512/app.trc/<0/<238 SLEEP/4000/1 SPEED/9600/b0096 После заливки аппа
  • Голов теперь только 2-е Age=4F Type=1E MxCyl=1A0F9 MxHd=1 MxSct=000
  • Вобщем вернул головы все на место, ввел двух
  • грузите всё в память(апп,церт+церттаблицы) s/n вбивайте,далее T>kff T>k2,FB T>H,,22 T>N2,,22 ctrl+T Может и голова
  • Вот теперь такой лог старта у харда. Теперь
  • JETWAY сделал как вы сказали по
  • сначала нужно серийник вбить,а потом уже команды на
  • JETWAY Спасибо за отзывчивость. Я тоже заметил
  • пробуйте всё грузить в память потом серийники с банки
  • Запустил тест с 10-го. Чрез часов 7-8 написал
  • Да
  • JETWAY Спасибо Я это и имел
  • Почему 3 ? Ну сколько можно уже одно и
  • NiTr0 а по порядку действий и
  • Если не ошибаюсь - что угодно, хоть
  • И так первый шаг пройден. Сегодня после работы попробую
  • Прошу прощения за тугодумность, но на всякий случай
  • Нет, при заливке в винт прошивка
  • NiTr0 уже не только блокнотик сделал,
  • И блокнотик для конспектирования не забыть
  • Powerman спасибо вам за отзывчивость. Ветку seagate
  • Я выставляю скорость из T так STR/b576/0///0/0 SPEED/57600/ CERT Скрипт
  • И ещё вопрос. Вычитал что вотетот серт который слит
  • Подскажите пожалуйста. Для того чтобы процесс сливания не занимал
  • В файл st_mem\mask\trc.txt вставить строчку TONKA15/0*16* Это не
