1)При использовании CBROM 2.07 + bp-4rc_F из COMMAND
1)При использовании CBROM 2.07 + bp-4rc_F из COMMAND PROMT под WinXP
Пишет:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\Ronin>C:\downloads\TESTTER\bp-4rc_F 75kavq11
BIOS_Patcher ver. 4.0_RC.F from "Second_Hope utils".
Warning! Recommended for power-users!
error!
0012 No more matching files
(c)2002 apple_rom, www.ROM.by
C:\DOCUME~1\Ronin>
2)При том же ,только из коммандной строки ипод NC (опять таки из винды)
Пишет:
C:\DOWNLO~1\TESTTER>bp-4rc_f.exe 75kavq11.bin /m
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support :for skip this step press "s" or any another key fo
-> fixed....
3. New Koeffs Support : not request to fixed.
4. 32Gb-problem(32g) : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : not request to fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : not request to fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : not found.
for skip this step press "s" or any another key for continue...
14.Set "Y" as default on exit: not found.
change_lo_not_found!
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 23.7%
Adding start.tmp 87.5%
3)При использовании CBROM 2.07 + BP-4_51 из COMMAND PROMT под WinXP
Пишет:
C:\Documents and Settings\Ronin>C:\Downloads\TESTTER5\BP-4_51 75kavq11 /m
BIOS Patcher ver. 4.51.
Can`t found "lha.exe"! www.ROM.by/Award/patcher/lha.exe
(c)2002-2003 apple_rom, www.ROM.by
4)При том же ,только из коммандной строки ипод NC (опять таки из винды)
Пишет:
C:\DOWNLO~1\TESTTER5>bp-4_51.exe 75kavq11.bin /m
-> fixed....
Mobile AMD Multipl-r adding :0000for skip this step press "s" or any another ke
-> fixed.inue...
2. XP frequency :for skip this step press "s" or any another key fo
-> fixed.his step press "s" or any another key for continue...
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
11.New Stepping Support : is not needed to be fixed.
Tweak options addinng:
Bus Disconnect Support : -> fixed.her key for continue...
FID_Enable adding : -> fixed.
Display Features adding : -> fixed.
Adding modul.tmp 37.5%
Adding tweak.tmp 65.5%
Какой из случаев правильный?
Какой из методов наиболее благоприяный(я о 1) и 4)?
Где есть ошибки?
Над чем еще можно поработать?
Каким пачером пользоваться 4.51 или 4.0_RC.F ?
Спасибо за помощь!
KT133A и Атлон ХП 1800+(переделанный в мобильный)
  • как говориться: не тормози - сникерсни иди на главную
  • Кто создатель? Какая у создателя конфигурация? Меняеться до 24Хт только
  • именно так, по крайней мере у меня
  • Всмысле??? Скажем у меня в проце заложено 11.5. Так
  • по-мойму bp-4rc71 был перед 4.10 --- Правда шил на Биос
  • Так я и шил BP-4_51_beta. Правда шил на Биос
  • мдя, ну что я могу тут сказать ... могу
  • Шил так. Скинул на дискетку пропатченый Биос+Awdflash +autoexec(в нем команда
  • Нет, не добавляет ... это и реализовано
  • Это хорошо ,что выподчеркиваете что 4.51 последняя версия. Только
  • еще раз замечу ИМХО последняя 4_51_бета и шить
  • Закрасил мостик L5(2) как надо. Bios видит :Unknown CPU
  • DanZer KEHT Спсибо за советы . Попробую отпишу!!!
  • вот товарищ DanZer правильно говорит, надо сначала канавку
  • А разрезы на мостиках суперклеем или лаком
  • Только что попробовал закрасить L5(2). Обклеил все скочем.Сделал окошко
  • Прошил свой 75kavq11 модифицированный прошивкой bp-4rc71. Все стало. Процессор пока
  • на сколько я понимаю последняя разработка все же
  • Попробовал 4rc71 Пишет E:\ПРОГИД~1\NEQ>bp-4rc71.exe 75kavq11.bin /m BIOS_Patcher ver. 4.0_RC.7.1 from "Second_Hope
  • Прочитал тут: http://www.radeon2.ru/ubb/Forum17/HTML/000144.html Я понимаю так ,что появилась скрытая и
  • "+PCI" для VIA добавлена уже давно,
  • Скажите есть ли вереятность того что новые
  • Я читал стартовую страницу. Там говориться чновый пачер только
  • Версия 4.51 подверглась серьезной переработке по сравнению с
  • Фух. Все подготовил: 1)Токопроводящий лак. 2)супер клей. 3)Офисный ножичек. 4)Прошил свой биос фирменной
  • 1)При использовании CBROM 2.07 + bp-4rc_F из COMMAND
  • 1. Еще раз - пользоваться версией 2.07
  • Получилось запустить! Проблема была в том что cbrom.exe с
  • Пардон, ошибочка вышла, не то ляпнул... :? Нужно
  • Видимо, Вы патчили под "чистым" ДОСом, без экстендеров
  • Докладываю о проделанном труде. Скачал: 1)bp-4rc_F 2)CBROM130 3)LHA 4)REALL.COD Все вроде сходиться. Записываю!!! CBROM130 LHA REALL.COD в папку в
  • Хочу принести свои извинения если оскорбил чувства и
  • 2Ronin Автору предоставляется огромная честь - решить,
  • Блин !!! На каждом сайте каждый пишет по своему... Кто
  • Хм.. А зачем постить сразу в 2-х ветках
