Вот тема у девушки. Вот БИОС AOpen AP5VM. Патчеры 6.хх пишут, что проблем 32/65Гб не найдено.
BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required! Found 1Mbit AMI BIOS (core 0627) ! !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! 4. 32Gb-problem : not found. 7. 65Gb-problem (1-st step) : not found. 8. 65Gb-problem (2-nd step) : not found. Tweak options addinng: !! Module Manipulation Successful !! !! Module Manipulation Successful !! !! Module Manipulation Successful !! if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by (c)2006 Angel07, www.cgi-scripts.info
