Hi, first, sorry, I don't understand anything in Russian. I have a Abit KT7a v1.1 (KT133a with an Thunderbird 1 Ghz), and bios A9 patched with Bios Patcher v6a15. 1) I understood that pressing the key "-" during the boot loads the "old" A9 firmware. Is it true ? 2) Sometime, the BiosPatcher logo and new bios date disappear (even if I don't press the "-" key). Is it normal ? 3) I'm going to buy an Athlon XP-M 2800+ (Mobile Barton), I hope to make it work with my card. I saw the /a option in bios patcher : "/a - select multipl-r for Mobile AMD processor: "/a3"=3.0x, "/a16.5"=16.5x etc" What's the aim of this option ??? Will it be useful for me ? I don't understand. Thanks ----------------------------------------------------- BIOS Patcher ver. 6.00.alpha_15. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required!
Hi,
![](/images/smiles/icon_smile.gif)
Thanks
Found 2Mbit Award BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support : -> fixed.
Adding AMDK7NOW! support : -> fixed.
2. XP frequency : Show only REAL frequency (in MHz).
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
Add new freq in BIOS Setup: 133/33MHz>124/31MHz>130/32MHz>
14.Set "Y" as default on exit: not found.
Tweak options addinng:
Bus Disconnect Support : -> fixed.
Display Features adding : -> fixed.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 39.0%
Adding start.tmp 87.5%
Adding tweak.tmp 45.2%
(c)2002-2004 apple_rom, www.ROM.by
(c)2006 Angel07, www.cgi-scripts.info
