вот так выглядит лог Windy6 чип там другой (1100 а не 1000) и более навороченный бутлоадер.
FLB running @ 24576000Hz; Flash Drivers: MX29LV320xB detected. ------------------------------------------------------------ Product Version: 5-0-32 LibraryVersion: BeBoB Package (Release) LibraryBuildVersion: 7418 (2008-04-30 17:31:42) LibraryTag: UNKNOWN-TAG ------------------------------------------------------------ Starting Bootloader Level 1 - Verifying application image: failed Starting Image я Copyright 2000-2005 by BridgeCo AG, Duebendorf, Switzerland Type Start End Size Heap cached 0x60054ec0 0x60600000 0x005ab140/5943616 Heap non-cached 0x70600000 0x70800000 0x00200000/2097152 AHB0 cached 0x00400000 0x00410000 0x00010000/65536 AHB0 non-cached 0x00500000 0x00510000 0x00010000/65536 AHB1 cached 0x00410468 0x00418000 0x00007b98/31640 AHB1 non-cached 0x00510000 0x00518000 0x00008000/32768 TCMD 0x005411ac 0x00542000 0x00000e54/3668 TCMI 0x005819f8 0x00584000 0x00002608/9736 Text 0x40052e04 0x40400000 0x003ad1fc/3854844 Stacks Start End Size timer 0x005408a8 0x00540ca8 0x400/1024 supervisor 0x005404a8 0x005408a8 0x400/1024 user 0x00540ca8 0x00540e28 0x180/384 irq 0x00540348 0x005404a8 0x160/352 fiq 0x600548c8 0x600548e8 0x20/32 undef 0x60054848 0x600548c8 0x80/128 module: bootloaderHalInit... [ ok ] module: gpioModule... [ ok ] module: SysDevUart1... [ ok ] module: FlashDrivers... MX29LV320xB detected. [ ok ] module: bootloaderBaseInit... Found a 64kbyte blocked flash Persistent Paramet [ ok ] module: cneModule... CnE from Flasher at 0x10000, size: 0x10000 Found a 64kbyte blocked flash CneA set to 0x20080 CneU set to 0x30000 CneS set to 0x10000 [ ok ] module: persistentCnEParameter... [ ok ] module: bootloaderCopyPersParamsToCne... [ ok ] module: systemDataService... [ ok ] module: cneSystemDataMgr... [ ok ] module: AudioHWService... [ ok ] module: chekovModule... [ ok ] module: Windy6BL_HAL... Instantiating Windy6 hal [ ok ] module: stack1394... overload: isc:1, bmc:1, pmc:0, adj:0. with: isc:0, bmc:0, pmc:0, adj:0. overload: generation:2. with: generation:15. overload: /cfg/1394/ConfigurationRom/RootDirectory/AvcUnitDirectory/Version: 0x0 0010001 with: 0x00014001. [ ok ] module: FlashUpdateService... [ ok ] module: bldCommandProcessor... [ ok ] module: FirmwareUpdate1394... [ ok ] module: modPersParamCommand... [ ok ] module: flashBurn... [ ok ] module: bootloaderApp... [ ok ] System initialisation done. ------------------------------------------------------------ LibraryVersion: BSL_Windy6 (Release) LibraryBuildVersion: 7553 (2008-07-30 09:41:13) LibraryCVSTag: bld_sec_Sims_Windy6-5_0_32-7553_RC ------------------------------------------------------------ Id.Version: 2.1610691836 for HWID/HWVS: 1.1 this HWID/HWVS: 1.0 ------------------------------------------------------------ Bootloader Second Level: CRC ok! Id=00000000, V=00000000, 20080730-080407 UT Application: invalid image CNE Factory: CRC ok! Id=00000001, V=00001D81, 20080730-081156 UT Bootloader Level 2 Menu (Jul 30 2008, 10:00:08) ================================================ 1) Download Image and Config (CnE) 2) Download Image Only 3) Download resource pages 4) Start Image 5) Print Image Info 6) Mark Image as invalid 7) Config (CnE) to factory default 8) Program MAC address 0 9) Program GUID a) Set Start Mode b) Exit to Shell start download with xmodem... CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC download passed Bootloader Level 2 Menu (Jul 30 2008, 10:00:08) ================================================ 1) Download Image and Config (CnE) 2) Download Image Only 3) Download resource pages 4) Start Image 5) Print Image Info 6) Mark Image as invalid 7) Config (CnE) to factory default 8) Program MAC address 0 9) Program GUID a) Set Start Mode b) Exit to Shell Bootloader Level 2 Menu (Jul 30 2008, 10:00:08) ================================================ 1) Download Image and Config (CnE) 2) Download Image Only 3) Download resource pages 4) Start Image 5) Print Image Info 6) Mark Image as invalid 7) Config (CnE) to factory default 8) Program MAC address 0 9) Program GUID a) Set Start Mode b) Exit to Shell BSYSTEM_HALT: Resetting Reset Board... ootloader Level ю FLB running @ 24576000Hz; Flash Drivers: MX29LV320xB detected. ------------------------------------------------------------ Product Version: 5-0-32 LibraryVersion: BeBoB Package (Release) LibraryBuildVersion: 7418 (2008-04-30 17:31:42) LibraryTag: UNKNOWN-TAG ------------------------------------------------------------ Starting Bootloader Level 1 - Verifying application image: OK Starting Image я Copyright 2000-2005 by BridgeCo AG, Duebendorf, Switzerland Type Start End Size Heap cached 0x601417c4 0x60600000 0x004be83c/4974652 Heap non-cached 0x70600000 0x70800000 0x00200000/2097152 AHB0 cached 0x004038b0 0x00410000 0x0000c750/51024 AHB0 non-cached 0x00500000 0x00510000 0x00010000/65536 AHB1 cached 0x00410bf0 0x00418000 0x00007410/29712 AHB1 non-cached 0x00510000 0x00518000 0x00008000/32768 TCMD 0x005413c4 0x00542000 0x00000c3c/3132 TCMI 0x00583f08 0x00584000 0x000000f8/248 Text 0x400c2d7c 0x40200000 0x0013d284/1299076 Stacks Start End Size timer 0x00540c40 0x00541040 0x400/1024 supervisor 0x005406c0 0x00540ac0 0x400/1024 user 0x00540ac0 0x00540c40 0x180/384 irq 0x00540560 0x005406c0 0x160/352 fiq 0x6013e844 0x6013e864 0x20/32 undef 0x6013e7c4 0x6013e844 0x80/128 module: gpioModule... [ ok ] module: SysDevUart0... [ ok ] module: SysDevUart1... [ ok ] module: SysDevSPI... [ ok ] module: FlashDrivers... MX29LV320xB detected. [ ok ] module: cneModule... F CnE from Flashound a 64kbyte blocked flash Persistent Parameter at 0x10000, size: 0x10000 [ ok ] module: persistentCnEParameter... [ ok ] module: systemDataService... [ ok ] module: cneSystemDataMgr... [ ok ] module: AudioHWService... [ ok ] module: UIServices... [ ok ] module: HALCompatibilityService... [ ok ] module: chekovModule... [ ok ] module: Windy6_HAL... Instantiating Windy6 hal [ ok ] module: StreamDeviceManager... [ ok ] module: StreamDeviceObserver... [ ok ] module: IsoStreaming... [ ok ] module: stack1394NoBusReset... [ ok ] module: modCMP... [ ok ] module: bldCommandProcessor... [ ok ] module: StreamDeviceAv... [ ok ] module: StreamDeviceArm... [ ok ] module: StreamDevice1394... [ ok ] module: StreamDeviceFramer... [ ok ] module: StreamDeviceDeframer... [ ok ] module: Services1394... [ ok ] module: AVCStack... [ ok ] module: AVCConnectionMgnt... [ ok ] module: HighSpeedCtrlService... [ ok ] module: StreamMonitor... [ ok ] module: StreamingFrmWrk... [ ok ] module: DataStreamManagement... [ ok ] module: sdsShellModule... [ ok ] module: flashBurn... [ ok ] module: Application... ------------------------------------------------------------ LibraryVersion: Infrasonic Windy6 App (Release) LibraryBuildVersion: 7962 (2009-07-01 09:51:10) LibraryCVSTag: Sims_Windy6-5_1_32-7962_RC ------------------------------------------------------------ Execute batch from No leaf name "" found sdsShell ready for commands. Try "help" for help. sds://> *** Running IEEE1394 *** ~~~~~~~~~~~~~~~ Standard mode ~~~~~~~~~~~~~~~ ---------------------------------------- >>input impedance: switched input 1 to [ ok ] System initialisation done. 6 x 6 channel playback process is running 'standalone' 6 x 6 channel recorder process is running 'standalone'
карта ожила
