Похоже, что всё-таки чип в короткую
по прошивке и сборке: " а они на самом деле, у неё на лбу сидели"
// // defines for Fireworks flash // Using bottom boot Intel TE28F160C3 flash part // #ifndef _INTEL_BOTTOM_BOOT_MAP_H_ #define _INTEL_BOTTOM_BOOT_MAP_H_ //----------------------------------------------------------------------------- // // Defines for Intel flash part // //----------------------------------------------------------------------------- #define PROGRAMBLOCK_SIZE_WORD16 0x1000 // 16-bit words #define MAINBLOCK_SIZE_WORD16 0x8000 // 16-bit words #define PROGRAMBLOCK_SIZE_BYTES (PROGRAMBLOCK_SIZE_WORD16 * 2) #define MAINBLOCK_SIZE_BYTES (MAINBLOCK_SIZE_WORD16 * 2) #define PROGRAMBLOCK_SIZE_QUADS (PROGRAMBLOCK_SIZE_WORD16 / 2) #define MAINBLOCK_SIZE_QUADS (MAINBLOCK_SIZE_WORD16 / 2) #define MAINBLOCKS_BASE_OFFSET_BYTES 0x10000 #define FLASH_SIZE_BYTES 0x200000 // 2 MB #define FLASH_SIZE_QUADS (FLASH_SIZE_BYTES / 4) //----------------------------------------------------------------------------- // // memory map // // Small blocks (8 kbytes each) from 0 - 0xffff // Large blocks (32 kbytes each) from 0x010000 - 0x1fffff // //----------------------------------------------------------------------------- // // Fireworks 2.1 // #define DSP_EMERGENCY_IMAGE_OFFSET_BYTES_FW21 0x00140000 #define ARM_IMAGE_OFFSET_BYTES_FW21 0x00100000 #define DSP_IMAGE_OFFSET_BYTES_FW21 0x000C0000 #define FPGA_IMAGE_OFFSET_BYTES_FW21 0x00080000 #define BOOT_IMAGE_OFFSET_BYTES_FW21 0x00000000 #define SESSION_OFFSET_BYTES_FW21 0x00008000 #define ARM_IMAGE_OFFSET_QUADS_FW21 (ARM_IMAGE_OFFSET_BYTES_FW21/4) #define DSP_IMAGE_OFFSET_QUADS_FW21 (DSP_IMAGE_OFFSET_BYTES_FW21/4) #define BOOT_IMAGE_OFFSET_QUADS_FW21 (BOOT_IMAGE_OFFSET_BYTES_FW21/4) // // Fireworks 3 // #define FPGA_IMAGE_OFFSET_BYTES_FW3 0x00000000 #define ARM_IMAGE_OFFSET_BYTES_FW3 0x00100000 #define NAME_BLOCK_OFFSET_BYTES_FW3 0x001E0000 #define SESSION_OFFSET_BYTES_FW3 0x001F0000 // // Fireworks HDMI // #define FWHDMI_CLOCK_RATIOS_OFFSET_BYTES 0x00006000 #endif // _INTEL_BOTTOM_BOOT_MAP_H_
Похоже, что всё-таки чип в короткую![:(](http://bios.rom.by/img/smiles/icon_sad.gif)
