Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
не знаю, не знаю... База меняеться, но не коренным образом-топология что так, что так-полумост. Меняет же народ на полевики КП948. мне не легче от того что он мощнее когда нагрузка больше и ширина импульсов больше... а поскольку ключь тугой то величина ШИМ хуже, один еще не закрылся, второй уже открылся... Б-р-р-р. не то что полевички.
п.с. это всеравно что стрелять много или стрелять метко. и так и так попадаешь.
Что сказали татары прийдя на Русь? "Сдавайтесь русские-нас орда!"
И что им ответили русские?
"А нас-рать!" ) (с)
Привет!!!
Что бы такого не было, когда возникает сквозной ток, в базы транзисторов
ставят электролиты, которые закрывают базу, предохраняя транзисторы от
сквозного тока.
Когда ёмкость мала или упала, транзисторы разрываются током.
Расшифруй, а то непонятно- а
поскольку ключь тугой то величина ШИМ -
Имел в виду, что скорость переключения мала или скорость закрытия мала и
один транзистор догнал другой.
Там всё синхронно, посмотри, на старых БП эти кондюки были по 1.0 Мкф х 50 вольт,
а сейчас ставят от 4.7 до 10.0 Мкф.
Михаил.
Аватар пользователя egor-land
Какие сквозняки, о чём вы говорите , там такой запас по времени ,
что любой биполярник успеет рассосать всё что надо и закрыться раз пять или шесть за это время.
дьюти цикле равен 0,5 , частота инвертора к примеру 40кГц , время полупериода 12,5мкс, ключик на 6мкс открывается, а потом закрыт  столько же !!!
Сколько мне не рассказывали случаев взрыва силовых, всегда это происходило в момент включения, то есть блок мог десять минут назад быть выключен, а потом при включении бабах. Думаю как раз после отработки конденсатора мягкого старта, получается максимальная длина импульсов (если выходные емкости еще не успели зарядится), хард раскручивает шпиндель и т.д. На ходу же не разу не встречал чтоб рванули силовые встречно.
"Все могут короли".... Ребята 40кгц-для 300ват это такой трансище. freesoft.ru/pageview.html?id=667944&dl=0 скачайте прогу трансформер 3.0.0.3 и посчитайте У меня валяется тор 40х25х11 Это 336Вт для 40кгц.(500Вт-80кгц) Конечно, согласен, у них ферриты лучше - но все же - на тех мизерных трансах что стоять при 40кгц даже 200вт не снять - он насытиться. Дьюти цыкл 0,5-это номинальное значение при средней нагрузке. Вообще дюьти цыкл-это и есть величина ШИМ отношение времени открытого состояния к величине периода ШИМ. Максимум ну 90% для биполярников на 80кгц. И оно далеко не 50% особенно при таких конденсаторах на входе по 220-330мкф.
Можете проверить экспериментом - возьмите 250Вт Бп снимите защиту с Тл-ки. И нагрузите нихромовой проволокой эдак на 3мм толщины, ну ват Эдак на 100... потом увеличивайте мощность до заявленных ампер на каждом из силовых каналов... постепенно;) Ключи вылетят если не сразу-то через пару минут точно. Жаль, нет осциллографа смотреть это все... Схемотехника БП предусматривает снятие напряжения(пропорционально вышеупомянутому дьюти цыклу) с управляющего транса, для во избежания Шпецэфектов) И там вот как раз и заложен максимальный порог дьюти цыкла.
NMD правильно говорит- конденсаторы. но я ж не сквозняка боюсь в основном... а как раз вышеупомянутых, 40кгц. Да и потери. Возьмите любую книгу по импульсным источникам - везде скажут биполярник тугой(молчу про IGBT)!!! 40кгц-это в свичах в питании MC63034;) да ТЛ494... в БП - дешевая потому что. и то обычно 80-100кгц.
п.с. Не хочется разговаривать "на пальцах".
п.с.п.с. в лучшем случае КПД АТХ БП-80%
"А нас-рать!" ) (с)
На блоках на 494  с такими трансами максимальный КПД достигается на 20-30 килогерцах.
Ребята, а всё же интересно, на какой частоте работает ТЛ 494 в холостом ходу
и при нагрузке, например в 100 ватт.
И где лучьше всего померить???
У меня сейчас только на 6105 шиме бп лежит.
На выходе силового транса импульсы померить, после диодов уже постоянка.
Или на задающем конденсаторе у ШИМа.
Михаил.
Частота 494 одинаковая всегда, задается времязадающей цепью.
Давайте лучше про транзисторы, а то всё остальное как-то не в тему получается ( особенно про трансформаторы - есть отдельная тема ).
кроме дьюти цикле , который может сильно увеличиваться при пуске и макс. нагрузке,
есть ещё понятие мёртвое время ШИМ (деад тайм) которое собственно и гарантирует
отсутствие сквозных токов в ключах инвертора, на любых режимах его работы.
реализовано просто - обычная задержка около 1-2мкс перед открытием ключа.
в KA3511 и FSP3528  это есть точно и задаётся элементами обвязки, а в TL494 не помню , надо в даташите глядеть.
Такой вопрос:
Оправдано ли применение отечественных компонентов в БП? Транзисторы, интегральные стабилизаторы, ОУ?
Как насчет надежности?
Сам _ни разу_ не использовал, но рассматривается вопрос приобретения КРЕН, КП и пр.
Заранее спасибо!
