Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Моё мнение: не оправдано никаким образом. По транзисторам много брака и просто подделок. Стабилизаторы еще худо-бедно работают. У микросхем бывает просто "с новья" отламываются ножки... В общем печальная картина, покупайте только в случае крайней нужды.
Спасибо! Вы подтвердили мои мысли по этому поводу.
А производитель TL494 оказывается об этом и не знает
Пишет: "Maximum Duty Cycle 48% (typical)"
А dead-time control у TL494 осуществляется напряжением на 4 ноге, которой её обычно включают-выключают.
Наконец расшевелил "зубров"
2NMD494 на 5-й ноге относительно земли, в даташите есть, или на выходе 8, 11 ножки. Величину Шим будет видно.
2egor-landДа знаем... есть на шимках такое, на 494 не помню как уже... но опять же я не сквозных токов боюсь, а потерь, нагрева и низкой частоты!
Нужно будет разобраться-почитать даташиты... задержку открытия/закрытия 13007, задержку полевиков. полазить по инету, где то на форуме по-моему electronix.ru есть целый раздел, про проектирование Импульсников в MicroCap-е. Просто может, думал, может, кто уже знает, напишет, посоветует...
п.с. спасибо всем не безразличным, разберемся. На больших частотах труднее проектировать/изготавливать магнитные элементы, да еще и полумост. Может поэтому схемотехника такая.
Что сказали татары прийдя на Русь? "Сдавайтесь русские-нас орда!"
И что им ответили русские?
"А нас-рать!" ) (с)
2Mazayac ИМХО, мы разговариваем про разные весщи, 47%-это если каждый канал отдельно. 90%-это если общее время открытия к периоду (для каждого канала, сдвинутого по фазе на Пи/2). 50%-тем более фантастика. 100%-дьюти цыкл-это полностью открытый ключ/ключи.
"А нас-рать!" ) (с)
И что же мешает в двухтактном преобразователе одному ключу быть полностью открытому 50% времени, а второму - вторые 50%?
Не вижу в упор никакой фантастики.
Неидеальность магнитных, дискретных и полупроводниковых элементов. в частности наших ключей медленных... в "идеальном" импульсном БП любой топологии можно было бы крутить на частотах порядка мегагерц . не буду лезть в дебри теории…
"А нас-рать!" ) (с)
У 494 как-бы внутри на 4 ноге источник +0,1 вольт (при 4 ноге на общем).
atxbp.narod.ru/
А вот головоломка:
Транзистор TOBA 3866.
Стоит в дежурке блока Hipower 350W в дежурке. Корпус TO-220.
У меня звонится накоротко, не могу даже понять полевик или биполярный. Инет молчит. Одну единственную ссылку нашел на японском сайте (в иероглифах), и та не работает.
Чем менять? Не то 2N60, не то 13007...
Посмотрите по обвязке, какой стабилитрон стоит в схеме и сравните и имеющими схемами.
Нарисуйте схему дежурки и нам покажите.
Михаил.
