Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
В дежурке 2N60 достаточно. Там 5V 3A.
D209L лучше заменить. На W13009 .
3040 менять не стоит. Сейчас по +5 и +3.3 мощность небольшую отбирают.
16c20 можно на 20с100 но не стоит.
Вот электролиты если неизвестного производителя, то стоит заменить. И желательно продублировать керамикой.
Это почему же? Современные материнки под Атлоны много кушают как раз с +12В.
Я, правда, не сталкивался с Gembird на 400W, но если блок не совсем левый, то чтобы его разогнать, надо разбираться и с защитой по току.
Разве что найти шоттки с меньшим падением напряжения и в большем корпусе.
К тому же TDP у Athlon64 3000+ всего 65 вт. (Winchester)
У старых - Newcastle, ClawHammer - 89.
Venice - 51
Mazayac, UAM спасибо. Если кто-то может что-то добавить по доработке:
rom.by/forum/Gembird_400w_uvelichenie_moshchnosti_po_shine_12_V
Да никакой речи о "разгоне" и не идет. Ему бы просто явные косяки исправить
Слово "мощные " видимо надо убрать из названия темы.
тогда будут все транзисторы .....
(поднял спец. для Альберта)
По маломощным есть отдельная тема, посмотрим, надо ли сливать их в одну.
За время ремонтов бп накопилось немного донарских деталей
Хотелось бы узнать ваше мнение о данных транзисторах
D209L - горелых видел немеренно
TT2148
TT2144
13009 в большом корпусе - процент горелых виденных в таком корпусе 95%
С5352
D4515
2SC3320
2SC2625
3sd209-1
D304X - сколько выкинул горелых со счета сбился, что за фирма такая в виде значка тройного интеграла ?
C4106
13007 - всем известные, в чем отличие если первые буквыы D,E,J ?
13009 - всем известные, в чем отличие если первые буквыы D,E,J ?
TT2146
TT2194
C2335
C5679
C3039
C5353 - обычно в дежурке
C5027 - обычно в дежурке
C4161
C3150
C4242
отдельно по одному есть(стояли наверное в дежурках)
18605D2 мотороловский
MA649 маде ин жапан
хочется узнать что из этого можно применять понормальному чтобы небыло такого как с D304X, ваши так сказать наблюдения в этом вопросе
СХЕМЫ БП ATX http//techlabs.nm.ru/
С чем сам сталкивался.
D209L, по-моему, не любят перенапряжения. С варисторами служат дольше.
2SC4106, 2SC4161, 2SC4242 хорошие транзисторы, 7А.
TT часто дохли.
comphardw.narod.ru/PC/bp2.htm
как считаете реально ли такое работает?
есть пара 2sk1317
вот думаю стоит ли попробовать
