Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
dimon194
Спасибо огромное, оно
Erstmann
других нет под рукой, спасибо
Аватар пользователя UAM
Вызову наверное, много гневных отзывов, но для ремонта обычных двухтактных схем я использую:
В основном источнике 13007 и 13009( раньше - BUT11AF, а совсем давно - КТ872 и даже КТ839)
В дежурном - 13007 или BUT11AF для замены биполярок и 04N60 для полевых.
Для восстановления проблемных дежурок - TNY267
При цене <2$ этой микросхеме не нужна обмотка обратной связи, а из обвески надо добавить конденсатор на 0,1 мкф (SMD, паяется прямо на ноги IS) и пару резисторов на 2,2 мом.
Откусив одну ножку и разогнув остальные она ставится на место транзистора и остается протянуть один проводок от оптрона.
Правда, она работает на 132 кгц, поэтому вроде бы должны проявляться проблемы с 44 кГц гасащими цепочками, но пока я с ними не сталкивался.
Аватар пользователя Mazayac
TNY267 - для замены в схемах на полевике или с биполярным транзистором?
Люди помогите! Валяется у меня платка от эконом лампочек, но не тех что продают везде и всюду, а применяемая на суднах. (она плоская)  Ну так вот лампа сгорела, платка осталась. И на ней танзюки маленькие квадратики (менше чем ТО-220)
На них надписи MRC  BULD 118DB UO4152
Не подскажете что это такое, всё перерыл а найти инфу на них не могу
To Mazayac
Сама TNY267 на полевике, ставил ее в блоки где не смог разобраться.
А биполярки и так легко поднять.
Но трансформаторы от биполярок работают с ней.
To dimon194
BULD 118-D1
S-L, 700/400V, 2A, 20W, <-/4,9æs     SMPS, Electronic Light Ballast     integr. Damper-Di
MJE13005 и диод между коллектором и эмиттером.
UAM большое спасибо, вот если бы ещё и цоколёвочку.....
Распиновка BULD 118-D1
Взято из VRT disk 99
UAM Огромное спасибо
Аватар пользователя Rom
UAM, ходи сюда скорей...
Аватар пользователя krumarev
БП Gemberd 400W будет работать на системе Athlon64 3000+, Asus A8N-E, Radeon x600-pro с разгоном.
Посоветуйте более мощный транзистор на замену 2N60C (дежурка).
Заменять ли транзисторы D209L ( Vce - 400v, Vcb-700v, Ic - 12A, P - 100w), на
KSE 13009 L ( Vce - 400v, Vcb-700v, Ic - 12A, P - 130w)? Или есть что-то лучше?
rom.by/comment/126834 ошибка, по даташиту для D209L Vcb-700v а не 450v
Хотя все же D209L стоит заменить.
Немного не в тему:
чем более надежным заменить диоды:
SBL3040PT (Vrrm=40v,Vrwm=28v, Vdc=40,If(av)=30A, Ifsm=275A);
16c20c (Vrrm=20v,Vrwm=14v, Vdc=20,If(av)=16A, Ifsm=150A);
