Power Button Override and Deep S4/S5 a. The following
a. The following note is added to the PWRBTN# Description in table 2-8 Power
Management Interface Signals:
Note: Upon entry to S5 due to a power button override, if Deep S4/S5 is enabled and
conditions are met per section 5.13.7.6, the system will transition to Deep S4/S5.
b. The following is added as note 5 to table 5-23 State Transition Rules for the PCH and
applies to all Power Button Override statements in the table:
c. Table 5-32 Transitions Due to Power Button is modified as shown:
d. The Power Button Override Function sub-section of section 5.13.8.1 PWRBTN#
(Power Button) is replaced with the following:
If PWRBTN# is observed active for at least four consecutive seconds, the state machine
unconditionally transitions to the G2/S5 state or Deep S4/S5, regardless of present
state (S0–S4), even if the PCH PWROK is not active. In this case, the transition to the
G2/S5 state or Deep S4/S5 does not depend on any particular response from the
processor (such as, a DMI Messages), nor any similar dependency from any other
subsystem.
The PWRBTN# status is readable to check if the button is currently being pressed or
has been released. The status is taken after the de-bounce, and is readable using the
PWRBTN_LVL bit.
Note: The 4-second PWRBTN# assertion should only be used if a system lock-up has
occurred. The 4-second timer starts counting when the PCH is in a S0 state. If the
PWRBTN# signal is asserted and held active when the system is in a suspend state
(S1–S5), the assertion causes a wake event. Once the system has resumed to the S0
state, the 4-second timer starts.
Note: During the time that the SLP_S4# signal is stretched for the minimum assertion width
(if enabled by D31:F0:A4h Bit 3), the Power Button is not a wake event. As a result, it
is conceivable that the user will press and continue to hold the Power Button waiting for
the system to awake. Since a 4-second press of the Power Button is already defined as
an Unconditional Power down, the power button timer will be forced to inactive while
the power-cycle timer is in progress. Once the power-cycle timer has expired, the
Power Button awakes the system. Once the minimum SLP_S4# power cycle expires,
the Power Button must be pressed for another 4 to 5 seconds to create the Override
condition.
это оно? про s3# ничего не нашел 5 раз все пролистал. нашел только его бол аут ( D4 ) но это вряд ли поможет.
MSI H61M-P31/W8 не стартует
  • JBAT стабильно 3.22В до, вовремя и после
  • Это в варианте Mobile SFF :).
  • да и инглиш у меня хромает... буду
  • Power Button Override and Deep S4/S5 a. The following
  • спасибо.
  • intel.com Intel 6 Series Chipset and Intel
  • что-то не нашел я документации , только реклама
  • каждых 9 секунд происходит новый рывок кулера 1
  • Для начала стоит понять, почему S3# так
  • что замерять на юге ?
  • сейчас система начала ( вкл
  • Пока можно погадать в сторону ЮМ -
  • -------------------- до замыкания -------------------------вовремя----------------------после
  • PSIN#, PSOUT#, S3#, PS_ON#, RSMRST# - до
  • всетаки это я натупил. выводы совпадают и на
  • да я что-то после того ,как отписал тоже
  • Не стоит пока. Сначала желательно проверить
  • ну родственник почти подходит. на 99 ноге нет
  • Не знаю. Это один из близких
  • это уже на конденсаторе замерял
  • Это уже издевательство над матплатой :).
  • плата стартует если 2 раза резко передернуть Clear
  • плата включается раза с 30-го но я еще
  • именно так. Юг не греется в
  • Перенапряжение по +3.3VSB обычно не детектируется.
  • да вот и мне не нравится завышенное
  • 3,6 В - это многовато. Стабилизатор скорее
  • на данный момент плата после старта сразу уходит
  • Сдул. Плата включается и отключается, уходит в стендбай,
  • Выпаял . по выходу сопротивление сразу же стало
  • Сопротивление маловато, но стабилизатор должен работать. Т.е.
  • это всетаки стаб 3.3В и 3.3 В для
  • Может быть и отдельный стабилизатор для TPM
  • в мануале написано 2,3 VSB на одном из
  • Вы в этом уверены :D?
