I tried to translate better because it is illegible.
perhaps from Italian to Russian translates better than English ...
my matherboard P5B-VM DO with Q6700 4Mb XP 32 , bought some years ago after my precedent matherboard P5B-VM is die.
sometimes bluescreen,sometime stopped(must reset),but all OK i thought , maybe is the SYS-OP.
since I bought it,it has always had a problem with power-ons.Very recently,when I plugged it ON,
even if I power on, don't start, or it start after a few seconds or minutes,until a few days ago, when i turn off the PC
(but i let it connected to AC)and in the morning i find no way to power on.
i bought a functionant P5B SE on ebay,but, when arrived it was KO(spot on 363,bios changed(on chip),folded legs on cpu hoof).
I unsoldered 2 60T03GH(compatible)from the P5B SE to repair my old P5B-WM(i had problems with video card installed,so i used it disabled from BIOS) and
I found that the 2 mosfets P1703BLG on the left(lower down),of the video card heatsink,were burned.
I've been lucky,the PC now is working,so PSU,CPU,DDR2,etc..all is OK ma the asus "P5B-VM DO" have problem.
Another problem,the bios of the P5B-VM DO let me configure memory in a way i can see 3.75gb on XP.
the P5B-VM let me see only 2.75 mb,it's a voice on BIOS.
I bought the P5B-VM DO also for that at the time.
to repair i tested the 2 matherboard in parallel w multimeter, mosfet and capacitors,(not with voltage on).
I found 3 bad caps slightly inflated on the P5B-VM DO and i substitute , then i find the 9 capacitors
panasonic 680uf 4v that was exploded from the underside(under the processor heatsink ).
i unsolded 9 polimer capacitors 560uf 6.3v from the p5b se(tested) and i welded them on the P5B-VM DO.
I connect the CPU+heatsink+fan+memory+psu w all the cable,i reset the CMOS and i change the battery but there is no way to turn it on.
when i power on, with the screwdriver, the green led turn on but no fan spin.
I found a difference between the two matherboards.
both disconnected and with the batteries inserted, measuring in homs-resistance, with the grounded black connector and the red
on the flash (rectangle feet in green - zoom the image), on the working P5B-VM, the resistance is pulsating,with a frequency of about near 1 second,
it goes to infinity and goes back to zero (on off on off) but I can't measure any resistance.
I can't,I think it's the clock powered by the 3V battery,I mean the card gives the impression of be "alive" and in fact it works.
if i do the same on the P5B-VM DO i measure that resistance(homs)...no life,no clock.
0-ground____119k____0.79M___0.80M
0.769M_____0.77M____134k____126k
I thought, the bios was erased/burned,so I tried to reprogram it with the SPI/parallel connector and SPIPGMW.EXE.
only works if the 3 volt battery is in the board... I reprogrammed it,so the 25VF016B flash works.
but that don't change the situation, no life, no on off on off, no clock like in the P5B-VM.
reading , yours ,automatic repair manual I unsoldered the quartz TXC 14.3Lk01 from P5B SE and replaced the
TXC 14.3MW3B they are not identical but I can't find the datasheet.
the situation has not changed.
So i decided to write for a help .
моя материнская плата P5B-VM DO с Q6700 4Mb XP 32, купленная несколько лет назад после смерти моей предыдущей материнской платы P5B-VM.
иногда синий экран, иногда останавливается (необходимо сбросить), но все в порядке, я думал, может быть, это SYS-OP.
с тех пор как я его купил, у него всегда были проблемы с зажиганием. В последнее время, если я нажимаю «включить», он не запускается или запускается через несколько секунд или минут ... до нескольких дней назад, когда я вечером выключил компьютер
(но я оставил его подключенным к источнику переменного тока), а утром он больше не включался.
Я купил P5B SE, работающий на Ebay, но когда он прибыл, это был KO (спот на 363, BIOS изменился (на чипе), ноги согнуты в разъеме процессора).
Я стаккато 2 60T03GH - P5B SE(совместимые) для ремонта моего старого P5B-WM (у меня были проблемы с установленной видеокартой, поэтому я отключил ее из BIOS) .
Я обнаружил, что 2 Mosfets P1703BLG слева (внизу), радиатора видеокарты, они они не работали.
Мне повезло, ПК сейчас работает, поэтому БП, ЦП, DDR2 и т. Д. Все они идут хорошо, но у ASUS "P5B-VM DO" есть проблемы.
Другая проблема, BIOS P5B-VM DO, позволяет мне настроить память таким образом, чтобы я мог видеть 3.75gb в XP.
P5B-VM показывает только 2,75 Мб, это запись BIOS.
Я купил P5B-VM DO для этого.
Для ремонта я тестировал 2 Matherboard параллельно с мультиметром, мосфетом и конденсаторами (не при включенном напряжении).
Я нашел 3 плохих колпачка, слегка надутых на DO P5B-VM, и я заменяю их, поэтому я нахожу 9 конденсаторов
Panasonic 680uf 4v резина,под конденсатором он вышел,жидкость вышла(под радиатором процессора).
Я распаял 5 полимерных конденсаторов 560 мкФ 6,3 В от p5b, если (тестировал) и припаял их на DO P5B-VM.
Я соединяю процессор + радиатор + вентилятор + память + блок питания со всем кабелем, сбрасываю CMOS и меняю батарею, но включить ее невозможно.
при включении отверткой включается зеленый светодиод, но вентилятор не включается.
Я нашел разницу между двумя Matherboards.
отключен от БП и с вставленными батареями , измеряя сопротивление , с черным заземленным разъемом и
Фило Россо Суй Пьедини Делла BIOS FLASH
(зеленым цветом на изображении - увеличьте изображение), на рабочем P5B-VM сопротивление пульсирующее, с частотой около 1 секунды,
он уходит в бесконечность и возвращается к нулю (вкл выкл вкл выкл), но я не могу измерить сопротивление.
Я не могу, я думаю, что это часы с батарейным питанием 3 В, я имею в виду, что карта выглядит «живой» на самом деле это работает.
если я делаю то же самое на "P5B-VM DО", я измеряю это сопротивление (эти значения) ... нет жизни, нет часов.
0 земель ____ ____ 119k 0,79M ___ 0,80 м
0,769M _____ 0,77M ____ 134k____126k
Я думал, что BIOS был удален / записан, поэтому я попытался перепрограммировать его с помощью SPI / параллельного разъема и SPIPGMW.EXE.
Работает только в том случае, если в карте есть батарея 3 В ... Я перепрограммировал ее, поэтому работает вспышка 25VF016B.
но это не меняет ситуацию: не кажется "живым", как в P5B-VM.
читая инструкцию по ремонту автоматический, я распаял кварц TXC 14.3Lk01 от P5B SE и заменил
TXC 14.3MW3B не идентичны, но я не могу найти данные.
ситуация не изменилась.
Поэтому я решил написать о ищу помощь.
P.S. ".... someone that ...." --> ".... that someone ...."
