Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Подскажите подскажите чем можно заменить IPP60r190c6
и до кучи диод BYC10-600?
Есть несколько другое мнение о назначении DR-цепочки. Во-первых, исключение сквозного тока обеспечивается определённым временем отсутсвия импульса для открытия второго транзистора. Конденсатор между выводом обмотки трансформатора является разделительным, а цепочка предназначена для быстрого разряда конденсатора во время отсутствия импульса, которое исключает сквозной ток через транзисторы. Обычно достаточно ёмкости конденсатора 1 мкФ, поэтому резистор применялся достаточно большой величины. Применение конденсатора большей ёмкости в более поздних моделях блоков обусловлено, на мой взгляд, для увеличения продолжительности работы блока. Естественно, резистор пришлось уменьшить в более ранних моделях до 39 Ом, потом до 22, встречались даже 4,7 Ом или вовсе заменён другим диодом.
Это заблуждение.
Принцип работы и назначение базовых элементов ключа дввухтактного полумостового инвертора приведено из букваря ЭУАИТ ( электронные устройства автоматики и телемеханики). Откройте , почитайте.
Электролит к тому же форсирует отпирание ключа , ключ меньше греется.
Например SPP20N60C3 или любым другим 20N60.
Я ставил BYC8-600, STTH8R06D, если блок до 600W.
ЗЫ. Блок случаем не chiеftec ?
remonter писал(-а):
Тут я с Вами согласен, но как он будет форсировать при приходе следующего импульса?
Аватар пользователя egor-land
Это чушь полная. Что ему тут разделять ?
Во-первых, это не другое мнение , это всего лишь дополнение к тому , что уже написал remonter
Эта задержка 1...2 мкс на отпирание ключа , формирутся контроллером ШИМ и называется Мёртвое время . Но для ислючения сквозняков этого мало. Поэтому во-вторых реализовано форсированное запирание ключа . И взрывы ключей при высыхании электролитов , наглядное тому подтверждение.
Естественно , что после запирания ключа, обратный ток базы резко падает и далее разряд электролита ( если он не полностью разрядился ) продолжается через RD чепочку , .
И это не другое мнение , а опять же дополнение к тому , что уже написал remonter.
egor-land писал(-а):
Т.е. Вы считаете, что конденсатор сначала поразряжается через резистор 2,7кОм, а потом, что останется, через диод и резистор в 22 ома. Из какого источника черпаете?
Здравствуйте,
есть вопрос - в блоке IP-S450Q3-0 стоят родные мосфеты P14NK50ZFP TO-220FP в изолированном корпусе, по даташиту у них мощность по 35 Вт ... это нормально ?? они обеспечат 450 Вт на выходе ? такие чаще вылетают ? можно оставить или срочно менять ?
(у таких же в неизолированном корпусе по 150 Вт)
Здравствуйте! Подскажите пожалуйста аналог транзистора cm2n60s, или чем можно заменить. Даташит не нашел(.
ramsujot писал(-а):
Даташит не нашел
Нда, бедный Google аж на первой странице:D выдает искомое от Shenzhen Jingdao Electronic Co.,Ltd.
