from 3.3vsb 2 chips of 4-resistance block are connect to the inputs of 83627 ..... the PSOUT (67) should be connect to 3.3vsb through one of these resistors
It isn't necessary.
PSOUT# may be connected to single resistor.
stf писал(-а):
tomorrow I look for a shovel and try to dig.
You'd better measure voltage in known points. Then you can "look for a shovel and try to dig" for unknown points.
