P5B-VM DO has LDO near PCI slots. I have already talked about it.
P5B-VM DO also has several linear regulators, which are based on discrete components.
stf писал(-а):
Seems that every coil w 2/3 CMOS and a 8 pin chip control some voltage,like if was many power supply, in the processor are 4 ...
1. Not CMOS. It's MOSFET.
2. 4 blocks (driver + 3 MOSFETs + coil) near CPU are 4 phases of one synchronous buck converter, which has one output voltage.
stf писал(-а):
normal ?
Don't do what you don't understand.
stf писал(-а):
is there a scheme for that matherboard to see if there is some components in parallel ?
You can use your eyes with glasses and see traces on motherboard.
You can also search in Web - P5B-VM DO boardview.
You do meaningless things and spend time. But you didn’t do what I wrote in the first comment.
Too much talk and not enough useful action
stf писал(-а): P5B-VM DO has LDO near PCI slots. I have already talked about it
stf писал(-а): 1. Not CMOS. It's MOSFET.
stf писал(-а): Don't do what you don't understand
stf писал(-а): You can use your eyes with glasses and see traces on motherboard
