Hummm ...
I'm doing it, but it's impossible ...
I mean also with the glasses and pins welded to the tips it is impossible not to short-circuit the pins of the 83627 i need references on the card, a resistor, a capacitor bigger ...
testing a MOSFET is a speech, but an SMD connected to PSU should be at 1.27 the distance btw pins , I risk do it on the grill ...
How do you do normally ?
Hummm ...
