ROM.by
  • Форум
  • Wiki
  • POST-коды
  • Последнее
  • Подшивка
  • Прочти меня
  • Ремонт материнских плат
    • Азбука
    • БД ремонтов матплат
    • Решебник
    • Самоучитель
  • Ремонт БП
    • Азбука по ремонту БП
    • Схемы БП
  • How to update BIOS?
  • Как перешить BIOS?
  • Материнские платы
    • Abit
    • Acorp
    • Asus
    • Chaintech
    • Elitegroup
    • Epox
    • Gigabyte
    • Intel
    • Microstar
    • Soltek
    • Остальные производители
  • Книга жалоб и предложений
  • Ромбокарта
  • Views Tracker
  • Популярное содержимое
  • Самодельная ИК станция
  • Регистрация
  • Забыли пароль?
You are wrong. RTC battery isn
15 Сен 2019 - 23:23 maco
Сказочник >> 27040 >> 1742.14
stf писал(-а):
I think it's the clock powered by the 3V battery
You are wrong. RTC battery isn't used for operations with SPI flash.
You can measure +3.3VSB on LDO near PCI slots.
If you have normal value +3.3VSB, you can measure voltage on PSIN#, PSOUT#, SUSB#, PSON#, RSMRST# pins (MIO).
P5B-VM DO die
  • No, I don't know :).
  • no i don't read it Harghhhhhhhh ! i
  • I gave you link. You didn't
  • 1)i forget, i find the driver for XP
  • 1. Drivers for Win XP. 2. You
  • Hi Maco, i'm going crazy ... The old CRT
  • North bridge capability and memory module
  • Questions ... 1) both P5B-VM and P5B-VM DO motherboards have
  • IMHO yes.
  • so PSU,CPU,DDR2,etc..all is OK stf later писал(-а): but the problem
  • OK i solved! I made the measurements but it's
  • It isn't necessary :). PSOUT# may
  • problem: searching for equivalent contact i can find 1)RSMRTS 2)PSON 3)PSIN 4)3.3 VSB not
  • I use thin tip probe for
  • Hummm ... I'm doing it, but it's impossible
  • Too much talk and not enough useful
  • Hi Maco, I know what is flash a bios,but
  • Do you really not see the
  • Hi, Thanks maco, it's the first time i put
  • You are wrong. RTC battery isn't
ROM.by 2002-2019 © apple_rom
Яндекс.Метрика
