T>(( VALID Cert Disk Code Detected - Revision # .006
T>y
PhysCyl GrayCyl
First System Cylinder 0000EC7B 0000F68E
First Zero Offset Cylinder 0000EC85 0000F698
First App Code Cylinder 0000EC90 0000F6A3
Second App Code Cylinder 0000EC91 0000F6A4
Second Zero Offset Cylinder 0000EC9C 0000F6AF
Third App Code Cylinder 0000ECA7 0000F6BA
Fourth App Code Cylinder 0000ECA8 0000F6BB
First Adaptives Cylinder 0000ECA9 0000F6BC
First User Defect List Cylinder 0000ECAA 0000F6BD
First Alternate Pool Cylinder 0000ECAE 0000F6C1
Second User Defect List Cylinder 0000ECBE 0000F6D1
First Cert Code Cylinder 0000ECC2 0000F6D5
First Intf Code Cylinder 0000ECC4 0000F6D7
First Intf System Cylinder 0000ECC6 0000F6D9
First SEADEX Cylinder 0000ECCC 0000F6DF
First Cert Log Cylinder 0000ECDE 0000F6F1
First Decay Cylinder 0000ECF5 0000F708
First SPLASH Cylinder 0000ED02 0000F715
Last System Cylinder 0000ED02 0000F715
T>
T>
RL:0200
AL:0203
SL:021A
RD:0400:0010
WR:0410:0010
FM:0420:0007
AD:0420:000B
BA:0427:0003
ST:042A:0001
AC:042B:01FF
DP:042B:01FF
AS:062A:007F
SC:06A9:0201
logbps :0200
codebps:0200
uP:3FE0
MZ:3FE0
T>
T>(( VALID Cert Disk Code Detected - Revision # .006 T>y PhysCyl GrayCyl First System Cylinder 0000EC7B 0000F68E First Zero Offset Cylinder 0000EC85 0000F698 First App Code Cylinder 0000EC90 0000F6A3 Second App Code Cylinder 0000EC91 0000F6A4 Second Zero Offset Cylinder 0000EC9C 0000F6AF Third App Code Cylinder 0000ECA7 0000F6BA Fourth App Code Cylinder 0000ECA8 0000F6BB First Adaptives Cylinder 0000ECA9 0000F6BC First User Defect List Cylinder 0000ECAA 0000F6BD First Alternate Pool Cylinder 0000ECAE 0000F6C1 Second User Defect List Cylinder 0000ECBE 0000F6D1 First Cert Code Cylinder 0000ECC2 0000F6D5 First Intf Code Cylinder 0000ECC4 0000F6D7 First Intf System Cylinder 0000ECC6 0000F6D9 First SEADEX Cylinder 0000ECCC 0000F6DF First Cert Log Cylinder 0000ECDE 0000F6F1 First Decay Cylinder 0000ECF5 0000F708 First SPLASH Cylinder 0000ED02 0000F715 Last System Cylinder 0000ED02 0000F715 T> T> RL:0200 AL:0203 SL:021A RD:0400:0010 WR:0410:0010 FM:0420:0007 AD:0420:000B BA:0427:0003 ST:042A:0001 AC:042B:01FF DP:042B:01FF AS:062A:007F SC:06A9:0201 logbps :0200 codebps:0200 uP:3FE0 MZ:3FE0 T>
