выкладываю лог. Патчил без ключей. BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (4.5x)!
1. New CPU Support : -> fixed.
2. P3-detect error : -> not found.
3. New Koeffs Support : -> fixed.
4. 32Gb-problem : -> fixed.
5. Some HDD detect-problem : -> fixed.
6. "MB"/"GB" string search : -> fixed.
7. 65Gb-problem (1-st step) : ->fixed.
8. 65Gb-problem (2-nd step) : ->fixed.
9. Error display Freq>999MHz : -> fixed.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : -> fixed.
12.Tualatin L2-init error : -> fixed.
13.New Freq in Setup open : -> not found.
14.Set "Y" as default on exit: -> fixed.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 35.2%
Header sum error
Adding start.tmp 87.5%
Adding cpucode.bin 58.5%
(c)2002-2003 apple_rom, www.ROM.by
Прошивал утилитой awarflash 8.22a
awardflash 6ltl0331.bin /py/cd/cc/cp/sb/r
в последние 2 блока при прошивке изменения не занесены!!!
Не хочет шиться пропатченый биос
