Bus 0 (PCI), Device Number 10, Device Function 0
Vendor 1106h VIA Technologies Inc
Device 3038h VT82xxxxx UHCI USB 1.1 Controller (All VIA Chipsets)
Command 0007h (I/O Access, Memory Access, BusMaster)
Status 0210h (Has Capabilities List, Medium Timing)
Revision 62h, Header Type 80h, Bus Latency Timer 20h
Self test 00h (Self test not supported)
Cache line size 32 Bytes (8 DWords)
PCI Class Serial, type USB (UHCI)
Subsystem ID 30381106h Unknown (Generic ID)
Subsystem Vendor 1106h VIA Technologies Inc
Address 4 is an I/O Port : 0000C400h
System IRQ 12, INT# A
New Capabilities List Present:
Power Management Capability, Version 1.1
Supports low power State D1
Supports low power State D2
Supports PME# signalling from mode(s) D0, D1, D2, D3hot, D3cold
PME# signalling is currently disabled
Current Power State : D0 (Device operational, no power saving)
3.3v AUX Current required : 375mA
Bus 0 (PCI), Device Number 10, Device Function 1
Address 4 is an I/O Port : 0000C800h
System IRQ 5, INT# B
Bus 0 (PCI), Device Number 10, Device Function 2
Device 3104h VT6202/12 USB 2.0 Enhanced Host Controller
Revision 65h, Header Type 80h, Bus Latency Timer 20h
PCI Class Serial, type USB 2.0 (EHCI)
Subsystem ID 31041106h VT6202 USB 2.0 Enhanced Host Controller (Generic ID)
Address 0 is a Memory Address (anywhere in 0-4Gb) : DF000000h
System IRQ 10, INT# C
Bus 0 (PCI), Device Number 10, Device Function 3
Device 3249h VT6421 IDE RAID Controller
Status 0290h (Has Capabilities List, Supports Back-To-Back Trans., Medium Timing)
Revision 50h, Header Type 00h, Bus Latency Timer 20h
PCI Class Storage, type RAID
Subsystem ID 32491106h Unknown (Generic ID)
Address 0 is an I/O Port : 0000CC00h
Address 1 is an I/O Port : 0000D000h
Address 2 is an I/O Port : 0000D400h
Address 3 is an I/O Port : 0000D800h
Address 4 is an I/O Port : 0000DC00h
Address 5 is an I/O Port : 0000E000h
Expansion ROM of 64Kb decoded by this card (Currently disabled)
Does not support low power State D1 or D2
Does not support PME# signalling
IRQ Summary: IRQs 5,10,11,12,14,15 are used by PCI devices
Shared IRQs: IRQ 10 is shared by 2 PCI Devices
IRQ 12 is shared by 2 PCI Devices
PCI Busses, Devices and Device Functions Tree
--Bus 0 (PCI)
|__Device 00h 8086h:7190h PCI to HOST Bridge
|__Device 01h 8086h:7191h PCI to PCI Bridge > Bus 1
|__Device 07h
| |__Function 0 8086h:7110h PCI to ISA Bridge
| |__Function 1 8086h:7111h IDE (ATA) Storage
| |__Function 2 8086h:7112h USB (UHCI) Serial
| |__Function 3 8086h:7113h PCI to Other Bridge
|__Device 0Ah
|__Function 0 1106h:3038h USB (UHCI) Serial
|__Function 1 1106h:3038h USB (UHCI) Serial
|__Function 2 1106h:3104h USB 2.0 (EHCI) Serial
|__Function 3 1106h:3249h RAID Storage
--Bus 0 (PCI)
|__Device 07h
|__Device 0Ah
--Bus 1 (AGP)
|__Device 00h 10DEh:0181h VGA Display
A total of 11 Devices Found
