Мощные транзисторы, применяемые в БП. Подбор и замена.
Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Аватар пользователя александр губа
Вечного ничего нет. Я бьі проверил дежурку под нагрузкой, если все "оккейно" - то так и оставить. ИМХО, как-то обезопасить дежурку можно заменой електролитов
Саша
С горячей стороны в дежурке нет электролитов...
Судя по всему первым ушёл 2n60, в короткое замыкание...что привело 300в на транс через резисторы... 1 ом сгорел,в базе 56 тоже сдох,ну и через затвор полевика выжгло и C945.
Очень повезло,что не успел повредится транс.... В следующий раз думаю он крякнет.
Аватар пользователя Bishop
хотел в раздел юмора, но тут более уместно будет... короче, продолжение темы "китайцы шутят"
youtube.com/watch?v=Jp9LGm6A3jk
наслаждаемся))
...ложки нет
Аватар пользователя kamysy2
Столкнулся с такой особенностью что мощные полевые транзисторы на одинаковый ток и напряжение в одном и том же корпусе имеют различную рассеваемую мощность согдасно даташит. Как в это случае быть выбирая замену? Обращать внимание на мощность или достаточно не превышать ток и напряжение при их замене в импульсных БП.
Аватар пользователя UAM
Обращать внимание на Rds
Чем меньше, тем меньше будут греться транзисторы.
Опять нюанс, нашёл по даташитам транзисторы с одинаковыми параметрами в том числе и по Rds при этом их мощности разнятся до семи раз.
Я понимаю, когда они в различгных корпусах, но когда они в одинаковых - это вызывает у меня вопрос. Может вопрос ещё и в технологии производства в результате которой изменяется теплопрводность от кристалла что впрочем влияет и на стоимость изделий. Полевики с большей мощностью и стоят дороже.
Пока же меня волнует вопрос как поступать при выборе замены этих транзисторов - обращать внимание на мощность по даташиту или не обращать, беря во внимание остальные ?
Какие именно транзисторы?
Может в импульсном режиме с разной скважностью?
Пример берём транзистор 20N60:
FCPF20N60 и 20N60C3 мощности 34,5 W и 208 W.
Таких примеров множество. Мне понадобилось заменить транзисторы PFV2 18N50 по даташит мощность 208 и 69 W как я понял в зависимости от корпуса.
У меня есть транзисторы FCPF20N60 по описанию мощность всего 39 W. Корпус как и у PFV2 18N50 ТО-220F.
Как результат остановился на транзисторах 24N60C3 в корпусе ТО-220.
Вероятно при замене кроме предельных параметров, обращать внимание на такие параметры как корпус и Rds
У корпуса большего размера рассеиваемая мощность больше. У корпуса с неизолированной подложкой - больше чем у корпуса с изолированной. При работе в линейном режиме по сравнению с импульсным как раз и получается тот разброс в даташитах, который вы описали. У нас используется импульсный режим. Так что ставим в том же корпусе, что и стоял и забиваем.
В 90% случаев смотрим на напряжение, ток и Rds On.
Когда начнете ремонтировать сварочники, тогда и начнете заморачиваться емкостью затвора, временем открытия и закрытия.
Mr.Barbara, я так и понял что на мощность влияет тип корпуса и Rds в ИБП для ПК. Спасибо.
