Вот небольшая подборка транзисторов, использующихся в БП.
Михаил.
KSC5027- Vceo-800V, Ic- 3A, Icp - 10A, Pd - 50W
2SC4242 - Vceo - 450v, Ic - 7A. Pd - 40W
BU508A - Vceo - 700V, Ic - 8A, Icp - 15A, Pd - 50W
ST13003 - Vceo-400v, Ic- 1.5A, Icp - 3A, Pd - 40W
MJE13003 - Vceo -400v. Ic -1.5A, Icp - 3A, Pd - 40W
2SC3457 - Vceo - 800v, Ic - 3A. P - 50w
MJE13005 - Vceo - 400v, Ic - 4A, Icp - 8A, Pd - 75w
MJE13006 - Vceo - 300v, Ic - 8A, Icp - 16A, Pd - 80w
MJE13007 - Vceo - 400v, Ic - 8A, Icp - 16A, Pd - 80w
2SC2625 - Vceo - 450v, Ic - 10A, Pd - 80w
2SC3306 - Vceo - 500v, Ic -10A, Pd - 100w
KSE13006 - Vceo - 300V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13007 - Vceo - 400V, Ic - 8A, Icp - 16A, Pd - 80W
KSE13009 - Vceo - 400v, Ic - 12A, Icp - 24A, Pd - 130w
KSP2222A - Vceo- 40v, Ic - 0.6A, Pd - 0.63w
2SC945 - Vcev - 60v, Ic - 0,1A, Pd - 0.25w
2SA733 - p-n-p Vce - 60v, Ic - 0.1A, Pd - 0.25w
2SA1015 p-n-p Vce - 50v, Ic - 0.15A, Pd - 0.4w
2SA1273 p-n-p Vce - 30v, Ic - 2A, Pd - 1.0w
2SB1116A p-n-p Vce - 80v, Ic - 1.0A, Pd - 0.75w
KSC2335F - Vceo-500v, Ic - 7A, Pd - 40w.
2SC2553 - Vceo-500v, Ic - 5A, Pd - 40w.
2SC2979 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC3039 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC3447 - Vceo-800v, Ic - 5A, Pd - 50w.
2SC3451 - Vceo-800v, Ic -15A, Pd - 100w.
2SC3460 - Vceo-1100v, Ic - 6A, Pd - 100w.
2SC3461 - Vceo-1100v, Ic - 8A, Pd - 120w.
2SC3866 - Vceo-900v, Ic - 3A, Pd - 40w.
2SC4106 - Vceo-500v, Ic - 7A, Pd - 50w.
2SC4706 - Vceo-600v, Ic -14A, Pd - 130w.
2SC4744 - Vceo-1500v, Ic - 6A, Pd - 50w.
KSC1008 - Vceo-80v, Ic -0.7A, Pd - 0.8w.
2SA928A p-n-p Vceo-20v, Ic - 1A, Pd - 0.25w.
ZTX457 - Vceo-300V Ic - 0.5A, Pd - 1,0W
2SC2954 SOT-89 Vcbo - 35V Ic - 0.15A P = 2W
------------f=500VHz Vcbo - 18V
2SC3303 2-7B1A Vcbo -100V Ic - 5A Pc =20W
---------------------------Vceo -80V Icp - 8A
2SC3866 SC-67 Vcbo - 900V Ic - 3A Pc = 40W
----------------------------Vceo - 800V
2SC4769 TO3PML Vcbo -1500V Ic - 7A Pc =60W
On-chip damper diode Vceo -800V Icp - 16A
2SC5129 2-16E3A Vcbo - 1500V Ic - 10A Pc =50W
------------------------------Vceo - 600V Icp -20A
2SC5250 TO-3P-FM Vcbo - 1500V Ic - 8A Pc =50W
damper diode-------------Vceo - ? Icp - 16A
2SC5352 2-16c1A Vcbo - 600V Ic -10A Pc = 80W
--------------------------------Vceo -400V Icp- 15A
2SC5353 SC-67 Vcbo -900V I c -3A Pc =25W
--------------------------------Vceo -800V Icp -5A
BU508A/ AF1 TO-218 Vces - 1500V Ic -8A Pc =125W
---------------------------------Vceo -700V Icm -15A
BU1508AX SOT186A Vcesm - 1500V Ic - 8A Ptot =35W
----------------------------------Vceo - 700V Icm - 15A
BU2520DF SOT199 Vcesm - 1500V Ic - 10A Ptot =45W
damper diode-----------------Vceo - 800V Icm -25A
BU2527AX SOT399 Vcesm - 1500V Ic - 12A Ptot = 45W
----------------------------------Vceo - 800V Icm -30A
BUH315D ISOWATT218 Vcbo - 1500V Ic - 6A Ptot =44W
damper diode-----------------Vceo - 700V Icm - 12A
Подскажите начинающему ремонтнику на что поменять IPW50R140CP? на STW34NM60N, IRFP22N50APBF или IRFP460PBF, это то что можно достать и похожее по параметрам. БП: Enermax 730w.
IPW50R140CP 550V 23-15A 0R14
STW34NM60N 600V 29-18A 0R105
IRFP22N50APBF 500V 22-14A 0R23
IRFP460A 500V 20A 0R27
Отсюда следует что лучшая замена это STW34NM60N 600V 29-18A 0R105
Можно ли заменить 2SC3320 на D209L?
ИМХО, ДА.
Но эти D209L ужасное го@но, ну разве если новое, не паяное, - но я бы не ставил!
Саша
Подскажите пожалуйста. Бп codegen RealPower 550w, хлопнули эти прОклятые d209l. Проблема в том, что они наклеили на кулер раскаленные куски резисторов, которые стоят база-эммитер и от базы в сторону конденсаторов. Может, у кого есть подобный или схема от этого блока номиналы определить. На плате рассмотрел r4,r5.
Тупо посмотреть в имеющиеся подобные схемы и подумать уже так трудно
Подскажите пожалуйста ключевой транзистор для блока Kinghun JX-H500A (раньше стояла пара P13009), один вылетел, хочу поменять парой.
Можно ли купить в Украине желательно на prom.ua со ссылкой, спасибо!
2 mr_grid возьми любой силовой NPN транзистор с напряжение коллектор-эмиттер не менее 700В, в подходящем корпусе.
У P13009 ток коллектора 12А, можно взять такой же, можно больше, можно меньше(например p13007 или p13005) - но в этом случае понимать что мощность у БП будет снижена (например в офисный ПК). Аналогов куча. можно российский КТ*** даже поставить
Если поставлю BU508AW у него напряжение коллектор-эмиттер 700В, а ток колектора 8А, в мощности потеряю?
В дежурке заменил 2N60B на 8N60 .... греется ,но не смертельно,потом попробывал GP10N60KD... холодные...
Эти просто были в наличии,хоть и IGBT....
Такие дежурки славятся выходом из строя полевика и кучи резисторов, в добавок бывает уносит и транс дежурки...
Вот ищу пути обезопасить дежурку....
