Дела такие при помощи MHdd удалил областьHPA. ДалееWinHex Записал
ДалееWinHex Записал прошивку в конец диска,
последний сектор
00000000 24 47 41 46 52 10 41 08 00 00 00 00 00 00 00 00
00000010 00 00 00 00 00 00 00 00 00 00 12 a3 f5 e1 00 00
00000020 00 00 00 08 00 00 00 00 00 00 00 00 00 00 00 00
00000030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000000F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000100 00 00 00 00 00 00 00 00 36 41 37 39 5A 47 30 38
00000110 EA 5B E0 00 F0 2A 4D 52 42 2A 02 00 00 00 60 00
00000120 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000130 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000140 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000150 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000160 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000170 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000180 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00000190 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Юзает диск примерно секунд30-40,а до этого 3-4.
Я думаю может прошивка не такая .Плата ga8ipe1000mk rev1.0.
rev1.0 на сайте нет, только ga8ipe1000mk (ga8ipe1000mk RS)
Скачал все и попробовал тоже все,прогресс только в том что Юзать стал дольше. f6/f7/f9/f10/f13/f14 И для RSpe1kmkrs.f10
Вопрос еще такой у меня последняя строчка BIOS
а на форумах читал
00 00 00 00 00 00 00 00 36 41 37 39 5A 47 30 4D
Меня смущает 38 и 4D для такойже платы
и еще может я не так забиваю сектор с которого начинается BIOS
1 2 3 4 5 6 7 8 9 10 A B C D E F
00 00 00 00 00 00 00 00 00 00 12 A3 F5 E1 00 00
сектор 12A3F51E00.
Помогите Bios GA-8IPE1000MK
