ROM.by
  • Форум
  • Wiki
  • POST-коды
  • Последнее
  • Подшивка
  • Прочти меня
  • Ремонт материнских плат
    • Азбука
    • БД ремонтов матплат
    • Решебник
    • Самоучитель
  • Ремонт БП
    • Азбука по ремонту БП
    • Схемы БП
  • How to update BIOS?
  • Как перешить BIOS?
  • Материнские платы
    • Abit
    • Acorp
    • Asus
    • Chaintech
    • Elitegroup
    • Epox
    • Gigabyte
    • Intel
    • Microstar
    • Soltek
    • Остальные производители
  • Книга жалоб и предложений
  • Ромбокарта
  • Views Tracker
  • Популярное содержимое
  • Самодельная ИК станция
  • Регистрация
  • Забыли пароль?
Volt-Ohm-Milliammeter, for example.
18 Июл 2014 - 13:55 maco
Сказочник >> 27126 >> 1742.14
Help me repair mainboard
  • 2 maco - with some individuals VOM
  • Do you mean ICH7? It consists of many
  • I want to ask how to determine south
  • Volt-Ohm-Milliammeter, for example.
  • try to rephrase you question, nothing can be
  • I want to know how the south bridge
  • thank you very much,so i hope you will
  • lexuanhoa , a little uncertainties appear here,
  • JTPM1 --> pin 3 --> voltage
  • I have sent mail to you. email: yeuthichvothuat@gmail.com.
  • Sorry, I do not have a schematic diagram
  • Dr.Rer.Nat писал (-а): precision, which is VTT_OUT_LEFT. VTT_OUT_LEFT.
  • you may guide me up display up community
  • To VTT_OUT_LEFT. If CPU
  • commonly, CPU_RST# has a pull-up resistor connection to
  • I'm currently fixing MSI G41-P28 mainboard series 7592-52.2
  • So I will take a picture and send
  • How (at which conditions) and where did you
  • hardly... Some more moments can be
  • thank you a lot, you can give me
  • everything is much simpler, numbers are 1,2,3 part1
  • thank you very much, I have seen many
  • Relating to your question about learning materials. There
  • is this cpu supported by the mainboard? What about
  • anyone can give me study material mainboard repair,
  • I checked the source vCore ok! but the
  • What do you mean "CPU is not working"?
  • I do not understand the reason why the
  • What happens than? :) What's the problem? Can you
ROM.by 2002-2019 © apple_rom
Яндекс.Метрика
