Автор: lexuanhoa , 1 июля 2014
you can help me repair mainboard ok???
Moved from here.
/images/koloboks/scratch_one-s_head.gif hardly... Some more moments can be understood from signals description, which can be found in official datasheets for chipset / microprocessors / system bus specifications...
How (at which conditions) and where did you measure that CPU_RST# is at low level (0.22 volt)? Was CPU inserted in the socket?
lexuanhoa
12 лет 3 месяца назад
So I will take a picture and send it to your mail, your comments are right for me. you can email me with your contact no???? thank you very much.
lexuanhoa
I'm currently fixing MSI G41-P28 mainboard series 7592-52.2
I used OVM test voltage CPU_RST #. when mounted on the CPU socket, check the power voltage CPU_RST # = 0.22v, compare well with the mainboard CPU_RST # = 1.23V voltage. I read on the forums can remove the IC share a com port communication. I did, but not at the moment.
commonly, CPU_RST# has a pull-up resistor connection to +GMCH_VTT, and is connected to corresponding pins of CPU socket on one side and north bridgge on the other. Did you check NB powers are Ok? Give, please, a measured resistance values from CPU_RST (pin "G23" at LGA 775) to ground and to GMCH_VTT output
[OFF]
To VTT_OUT_LEFT.
If CPU not present, then "to VTT_OUT_LEFT".[/OFF]
lexuanhoa
you may guide me up display up community is not, requires image to understand specify the problem over.
lexuanhoa
Dr.Rer.Nat писал (-а): precision, which is VTT_OUT_LEFT.
VTT_OUT_LEFT. = 1.23 v. 62R0402 resistor is R137.
Sorry, I do not have a schematic diagram of this mobo, if you have one, please. send it to levchenko.v@mail.ru
P.S.You can attach jpg files right to your posts at this forum, use "Прикрепленные файлы" link under text box while writing / editing message, than press button "Обзор", select a file and press "Прикрепить". After you have to copy an URL adress of attached picture and put into {    } tag Note size exclusion limits for the picture, is 800 x 600 pix
lexuanhoa
I have sent mail to you.
email: yeuthichvothuat@gmail.com.
