Автор: lexuanhoa , 1 июля 2014
you can help me repair mainboard ok???
Moved from here.
What happens than? :)
What's the problem? Can you tell the model of a mobo at least...
lexuanhoa
12 лет 2 месяца назад
I do not understand the reason why the cpu is not working.'ve fully checked the source. Please give me comments
note: mainboard MSI G41-P28 7592-5.2
thanks.
What do you mean "CPU is not working"? Is CPU_Vcore present?
Is DDR power (1.5V) present?
tell us the name of PWM controller of CPU VRM (a chip in qfn-package near socket)
Is your CPU Ok, and does it supported by this mobo? Check in CPU support list on official MSI website
lexuanhoa
I checked the source vCore ok! but the problem is, the cpu does not work, test card show FF, I checked the h_cpurst # 0.2v, compare well with the mainboard h_cpurst # 1.2v
lexuanhoa
anyone can give me study material mainboard repair, I was a repairman, but I need to know the principles of operation of a mainboard, I was out of warranty staff for MSI mainboard in Vietnam
is this cpu supported by the mainboard?
What about CPU_CLK?
It is commonly accepted to publish results of measurements here, including voltage values, signal names / component positional numbers. So feel free, exact values gain successful repairment :)
Relating to your question about learning materials. There is a series of excellent documets from ASUS exists, you cat try to find it via google using "MB Lx Training Materials", where x is a number of a document. Check this, for example
lexuanhoa
thank you very much, I have seen many articles in http://www.rom.by the mainboard or, but I do not know where to find it, you can just give me (give me the link to download the no ). thank you
lexuanhoa
12 лет 1 месяц назад
thank you a lot, you can give me more keywords to search for learning materials not edit mainboard. I want to better understand the principles of operation mainboard. I thank you
