CBROM V2.07 report.txt BIOS Patcher ver. 4.23. Attention! Advanced qualification is
CBROM V2.07
report.txt
Found 2Mbit BIOS (6.x)!
Found AMD K7-BIOS/platform!
1. New CPU Support : -> fixed.
1a.Bus Disconnect Support : -> fixed.
2. XP frequency : -> fixed.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
Add new freq in BIOS Setup: 100/33Mhz 110/33Mhz 120/30Mhz 133/33Mhz 140/35Mhz 150/38Mhz 166/33Mhz 170/34Mhz 180/36Mhz
14.Set "Y" as default on exit: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 41.4%
Adding start.tmp 87.5%
(c)2002-2003 apple_rom, www.ROM.by
Ну вроде усё написал как было...
Duron 1800 и ECS K7VTA3(ver. 3.0) - работать будет?
