А у меня вообще непонятно.
F3 T>^A Package Version: PH0G2D.CCD3.AA6H00.CC37 , Package P/N: 100585715, Package Bu ilder ID: AT, Package Build Date: 07/29/2009, Package Build Time: 16:07:42, Package CFW Versio n: PH0G.CCD3.00190668.AT00, Package SFW1 Version: D249, Package SFW2 Version: ----, Package SFW3 Version: -- --, Package SFW4 Version: ---- Controller FW Rev: 07291607, CustomerRel: CC37, Changelist: 00190668, ProdType: PH0G.CCD3, Date: 07/29/2009, Time: 160742, UserId: 00236537 Servo FW Rev: D249 RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03
F3 T>/1
F3 1>N1
SIM Error 1002 SIM Error 1002 SIM Error 1002 Init SMART Fail LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3 LED:000000CC FAddr:0024E4A3Ё Rst 0x10M SIM Error 1002 (P) SATA Reset
SIM Error 1002 SIM Error 1002 SIM Error 1002 PASS SIM Error 1002 SIM Error 1002 SIM Error 1002WriteDCOInfo FAILED during Initialization RW: Error processing Performance Parameter File: 203C PASS SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 ASCII Diag mode
F3 T>^L New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3 Product FamilyId: 3F, MemberId: 05 HDA SN: 5VM3EWZY, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 3A386030, PreampType: 73 01 PCBA SN: 0000K011BLG6, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_CO PPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000 Package Version: PH0G2D.CCD3.AA6H00.CC37 , Package P/N: 100585715, Package Bu ilder ID: AT, Package Build Date: 07/29/2009, Package Build Time: 16:07:42, Package CFW Versio n: PH0G.CCD3.00190668.AT00, Package SFW1 Version: D249, Package SFW2 Version: ----, Package SFW3 Version: -- --, Package SFW4 Version: ---- Controller FW Rev: 07291607, CustomerRel: CC37, Changelist: 00190668, ProdType: PH0G.CCD3, Date: 07/29/2009, Time: 160742, UserId: 00236537 Servo FW Rev: D249 RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03 Features: - Quadradic Equation AFH enabled - VBAR with adjustable zone boundaries enabled - Volume Based Sparing enabled - IOEDC enabled - IOECC enabled - DERP Read Retries enabled - LTTC-UDR2 disabled
F3 T> YetiST Rev: 649B; No Host; SpdLimit: No; SSC: Yes; LED: No; StagSpinByp: Yes;
SATA Block Registers ATA 400A0000: 0000 0000 0000 0000 0000 0000 0000 0000 400A0010: 0000 0000 0000 0080 0040 0000 0000 0400 400A0020: 0080 0000 0010 0210 0100 0100 0000 0000 400A0030: 0000 841B 0000 0000 0000 0000 0000 0000 400A0040: 0000 0000 0000 0000 0000 0000 0000 0000 400A0050: 0000 0000 4795 57A5 CE2D 0000 0000 0000 400A0060: 0001 0000 0000 0000 0000 0000 0000 0000 400A0070: 0000 0001 0000 0000 0000 0000 0000 0000 400A0080: 0000 0000 0001 0001 0000 0000 0000 0000 400A0090: 0001 0000 0000 0000 0000 0000 0000 0000 400A00A0: 0000 0000 0000 0000 0000 0000 0000 0000 400A00B0: 0000 0000 0000 0000 0000 0000 0000 0000 400A00C0: 0000 0000 0000 0000 0000 0000 0000 0000 400A00D0: FFFF FFFF FFFF FFFF 0000 0000 0000 0000 400A00E0: 0000 0000 0000 0000 0000 0000 0000 0000 400A00F0: 0000 0000 0000 0000 0000 0000 0000 0003 SATA Global 400A0100: 0000 0000 0000 Link Layer 400A0130: 0000 0000 0000 0000 8000 0000 0F00 0000 400A0140: 0020 0000 0000 0000 0000 0000 0000 0101 400A0150: 0000 0000 0000 0000 0000 0000 0000 0000 400A0160: 0000 0000 0000 0000 0000 0000 0000 0000 400A0170: 0000 0000 0000 0000 0000 0000 0000 0000 400A0180: 0000 0000 0000 0000 0000 0000 0000 0000 400A0190: 0000 0000 0000 0000 0000 0000 0000 0000 400A01A0: 0000 0000 0000 0000 0000 0000 0000 0000 400A01B0: 0000 0000 0000 0000 0000 0000 0000 0000 400A01C0: 0000 0000 0000 0000 0000 0000 0000 0000 400A01D0: 0000 0000 0000 0000 0000 0000 0000 0000 400A01E0: 0000 0000 0000 5032 5232 5032 5232 0000 400A01F0: 0000 0000 0000 0000 0000 0000 0000 0D00 Transport Layer 400A0250: xxxx xxxx xxxx xxxx xxxx xxxx 0000 000F 400A0260: 0000 0000 364B C46A 0000 0020 0000 3018 400A0270: 0000 0000 0000 0000 0000 0000 0000 0000 400A0280: 0000 0000 0000 0000 0000 0000 0000 0000 400A0290: 0000 0000 NCQ Cmd Validation 400A0300: 0000 0000 0000 0000 0000 0001 0000 0000 Application Layer 400A0390: xxxx xxxx xxxx xxxx 0000 0500 0000 5058 Shadow Task File 400A03A0: xxxx xxxx 0000 0000 0000 0000 0000 0000 400A03B0: 0000 0000 0000 0000 0000 0000 0000 0000 400A03C0: 0000 0000 0000 0000 0000 0000 0000 0000 400A03D0: 0000 0000 0000 0000 0000 0000 0000 0000 400A03E0: 0000 0000 0000 0000 0000 0000 0000 0000 400A03F0: 0000 0000 0000 0000 PhyPM Regs 400A0700: 0000 000F 0000 0000 0010 0000 0000 0000 400A0710: 0000 0000 0000 0000 0000 0000 0000 0000 400A0720: FFFF FFFF FFFF FFFF 0000 Physical Layer 400A0800: 0000 0000 0001 0000 0000 0000 0000 0020 400A0810: 0000 0001 0000 005D 2CC0 C9C5 9000 3333 400A0820: 364D A494 0800 96A8 1010 0004 0000 0000 400A0830: 0000 0406 0000 0000 0000 0000 0000 0000 400A0840: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 400A0850: 0000 0000 0000 0000 0000 0000 0000 0000 400A0860: 0000 0000 0000 0000 0000 0000 0000 0000 400A0870: 0000 0000 0000 0000 0000 0000 0000 0000 400A0880: 0000 0000 0000 0000 0000 0000 0000 0000 400A0890: 0000 0000 0000 0000 0000 0000 0000 0000
Shanghai390 Phy Registers TX 8000: 10 00 00 25 01 03 01 00 00 04 00 00 07 FF 07 80 8010: 00 RX 8600: 00 00 00 65 40 18 00 28 30 02 14 00 10 00 A0 10 8610: 00 00 00 00 00 0C B1 82 D4 FC A8 00 00 00 01 7C 8620: 83 FF 40 00 05 00 00 05 00 00 00 MCTL 8700: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8710: 01 00 00 00 00 00 00 00 00 00 00 AFE 8800: 18 05 08 00 00 13 04 0F 09 08 00 00 30 18 0A 00 8810: 18 05 00 01 SIF C000: 08 00 00 00 09 00 07 Wrapper C100: 02 00 C7 00 00 67 00 00 00 04 PatGen D000: 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D010: 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 55 D020: 55 55 55 55 CMU F000: 73 28 00 2E 0E 00 85 36 36 00 F4 39 0C 50 68 01 F010: 01 00 17 00 00 7F 1C 20 00 00 3D 19 19 00
VBM Cache Search Registers 40012680: 0000 0000 0000 0000 007F 0000 0000 00FF 40012690: 0000 0000 0000 0000 0000 0000 0000 0000
Traverser Regs 40012700: 0000 0000 0000
Host Data Manager Regs Bank 0 40012800: 0007 0000 7FFF 0000 0000 0000 0000 0000 40012810: 0000 0000 0000 0000 0000 0000 0000 0000
Disc Data Manager Registers Bank 0 40012900: 0CA7 0008 0080 0000 0080 0000 0080 0000 40012910: 0080 0000 0080 0000 0080 0000 0080 0000
PBM Memory Controller Registers 40012A00: 0090 000B 0008 0235 0033 4002 0029 4423 40012A10: 00A7 E600 E600 0092 0092 0000 0000 0000 40012A20: 0000 0000 0000 0000 0000 0000 0000 0000 40012A30: 2F00 0004 106B 000B FFFF 07FF 0000 0000 40012A40: FFFF 07FF 0000 0000 FFFF 07FF 0000 0000 40012A50: 0000 0000 6B82 0500 B026 9004 0DC8 300A 40012A60: 0000 0000 0000 0000 0000 0000 0000 0000 40012A70: 0000 0000 0025 0000 0000 0000 0000 0000
FDE Block 40012B00: 0000 0000 0000 0000 0000 0000 0000 0000 40012B10: 0000 0000 0000 0000 0000 0000 0000 0000 40012B20: 0200 20F0 B2A3 2734 3801 4986 0000 0000 40012B30: 0000 0000 0000 0000 0000 0000 0000 0000
Hardware Phy Event Counters 00000000: 0000 0000 0000 0000 0000 0000 0000 0000 00000010: 0000 0000 0000 0000 0000 0000 R_ERR on RX FIS Non-data: 00000, Data: 00000 R_ERR on TX FIS Non-data: 00000, Data: 00000
F3 T> Total process 100% complete Current operation is NOT aborted. Current status 0
F3 T>^U New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3 Product FamilyId: 3F, MemberId: 05 HDA SN: 5VM3EWZY, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 3A386030, PreampType: 73 01 PCBA SN: 0000K011BLG6, Controller: YETIST_3_0(649B)(3-12-3-3), Channel: AGERE_CO PPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 94, BufferBytes: 1000000 Package Version: PH0G2D.CCD3.AA6H00.CC37 , Package P/N: 100585715, Package Bu ilder ID: AT, Package Build Date: 07/29/2009, Package Build Time: 16:07:42, Package CFW Versio n: PH0G.CCD3.00190668.AT00, Package SFW1 Version: D249, Package SFW2 Version: ----, Package SFW3 Version: -- --, Package SFW4 Version: ---- Controller FW Rev: 07291607, CustomerRel: CC37, Changelist: 00190668, ProdType: PH0G.CCD3, Date: 07/29/2009, Time: 160742, UserId: 00236537 Servo FW Rev: D249 RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 09 08 03 Features: - Quadradic Equation AFH enabled - VBAR with adjustable zone boundaries enabled - Volume Based Sparing enabled - IOEDC enabled - IOECC enabled - DERP Read Retries enabled - LTTC-UDR2 disabled
F3 T>^U 00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F 0000: D8 05 00 00 00 08 53 43 88 00 00 00 01 10 01 00 0010: 00 00 00 00 00 00 0F 00 01 00 0A 00 A2 00 00 00 0020: 03 00 16 00 AE 00 00 00 04 00 16 00 C6 00 00 00 0030: 07 00 0A 00 DE 00 00 00 08 00 12 00 EA 00 00 00 0040: 0A 00 0A 00 FE 00 00 00 1A 00 0A 00 0A 01 00 00 0050: 3A 00 42 00 16 01 00 00 3C 00 3E 00 5A 01 00 00 0060: 00 00 46 00 9A 01 00 00 5C 01 0C 00 E4 01 00 00 0070: 7C 01 24 00 F4 01 00 00 7C 02 0C 01 1C 02 00 00 0080: 7C 03 38 01 2C 03 00 00 3E 00 70 01 68 04 00 00 0090: 48 05 00 00 01 10 00 00 00 00 00 00 FF FF 01 00 00A0: 81 0A C0 10 FF 00 00 00 05 00 FF FF 83 16 00 01 00B0: 00 00 00 00 00 02 00 03 02 00 00 01 00 00 00 00 00C0: 40 00 00 00 84 16 00 00 04 02 00 00 00 00 00 00 00D0: 00 00 00 00 00 00 00 00 1C 20 00 00 87 0A 00 10 00E0: FF 00 00 00 00 00 FF FF 88 12 14 00 FF FF 00 00 00F0: FF FF FF FF 80 20 00 00 00 00 00 00 8A 0A 02 00 0100: 00 00 00 00 00 00 00 00 9A 0A 00 02 00 00 00 05 0110: 00 00 8C A0 BA 42 00 05 00 00 00 00 00 0A 00 00 0120: 00 00 00 00 31 08 08 08 00 05 44 02 00 00 00 00 0130: 00 00 08 00 01 08 08 08 08 00 00 00 00 00 00 14 0140: 00 14 00 78 00 00 00 00 00 00 00 00 00 40 00 80 0150: 00 80 01 00 0A 01 00 00 BC 3E 00 70 00 00 00 00 0160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0170: 80 00 00 78 00 C8 00 00 00 00 00 00 00 00 00 00 0180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0190: 00 00 00 00 00 00 00 00 80 46 30 32 37 4A 4A 30 01A0: 44 54 58 20 20 20 20 20 20 20 00 00 00 00 00 00 01B0: 53 54 33 35 30 30 34 31 38 41 53 20 20 20 20 20 01C0: 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 01D0: 20 20 20 20 20 20 20 20 00 00 08 00 00 00 00 00 01E0: DC 01 0C 00 01 00 00 18 00 18 00 00 00 00 00 00 01F0: FC 01 24 00 00 11 11 11 11 11 11 11 12 11 11 10 0200: 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 11 0210: 11 11 11 11 11 00 00 00 FC 02 0C 01 00 00 00 00 0220: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0230: 00 00 00 00 00 00 00 00 80 00 00 00 F2 E8 80 00 0240: 00 A0 80 00 80 00 00 00 F2 E8 80 00 00 A0 80 00 0250: 80 00 00 00 F2 E8 80 00 02 A0 80 00 80 00 00 00 0260: F2 E8 80 00 00 A0 80 00 80 00 00 00 71 C8 80 00 0270: 00 A0 80 00 80 00 00 00 71 C8 80 00 00 A0 80 00 0280: 80 00 00 00 F2 E8 80 00 00 A0 80 00 80 00 00 00 0290: F2 E8 80 00 00 A0 80 00 00 00 00 00 11 C8 80 00 02A0: 00 A0 80 00 80 00 00 00 F2 E8 80 00 00 A0 80 00 02B0: 80 00 00 00 F2 E8 80 00 00 A0 80 00 00 00 00 00 02C0: 00 00 00 00 00 00 00 00 80 00 00 00 F2 E8 80 00 02D0: 00 A0 80 00 80 00 00 00 71 C8 80 00 00 A0 80 00 02E0: 00 00 00 00 F2 C8 80 00 00 A0 80 00 00 00 00 00 02F0: 00 00 00 00 00 00 00 00 80 00 00 00 71 C8 80 00 0300: 00 A0 80 00 00 00 00 00 00 00 00 00 00 00 00 00 0310: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0320: 00 00 00 00 00 00 00 00 FC 03 38 01 00 00 00 00 0330: 00 05 80 00 00 00 00 00 00 00 00 00 00 00 00 00 0340: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0350: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0360: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0370: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0380: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0390: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0400: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0420: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0430: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0440: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0450: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0460: 00 00 00 00 BE 00 70 01 FF 3F 10 00 3F 00 04 00 0470: 10 00 00 02 00 02 FF 3F 10 00 3F 00 10 00 07 7F 0480: 03 00 78 00 78 00 78 00 78 00 1F 00 0E 05 00 00 0490: 48 00 40 00 F0 01 29 00 6B 34 01 7F 63 41 69 34 04A0: 01 BE 63 41 00 00 FE FE FE FF 00 FE 00 00 00 00 04B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 04C0: 00 00 0E 40 08 40 08 10 00 00 01 00 0F 00 06 00 04D0: 03 00 00 00 32 00 14 00 33 00 24 00 0F 00 1E 00 04E0: 32 00 00 00 13 00 61 00 32 00 14 00 32 00 00 00 04F0: 3A 00 00 00 22 00 2D 00 32 00 00 00 32 00 00 00 0500: 32 00 00 00 22 00 00 00 1A 00 00 00 12 00 00 00 0510: 10 00 00 00 3E 00 00 00 32 00 63 00 32 00 00 00 0520: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0530: 32 00 00 00 0F 00 00 00 32 00 00 00 00 00 00 00 0540: 00 00 00 00 00 00 3F 10 37 3C 0A 0E 07 00 00 00 0550: 00 00 00 00 00 00 00 00 3B 00 00 00 00 00 00 00 0560: 00 00 00 00 00 00 00 00 00 00 00 00 40 04 00 15 0570: 20 00 20 01 00 00 00 00 81 A0 00 28 04 3F 00 00 0580: FF FF 00 00 00 00 00 00 00 00 00 00 4B 00 00 00 0590: 00 00 00 00 54 15 3C 00 0A 00 05 78 00 00 00 00 05A0: 00 08 00 00 04 00 01 FF 00 00 00 00 00 00 00 00 05B0: 00 00 00 00 00 00 00 00 00 00 00 20 FF FF 00 00 05C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05D0: 00 00 00 00 00 00 00 00
DriveNativeInfo Mode Page DriveNativeInfo Group Byte:019A: PartNumber = 30 32 37 4A 4A 30 44 54 58 '027JJ0DTX' Byte:01A3: PartNumberWhitespacePad = 20 20 20 20 20 20 20 00 ' ' Byte:01AB: PartNumberPad = 00 Byte:01AC: ProcessControlVersion = 00 00 Byte:01AE: CongenConfigurationState = 00 Byte:01AF: WrittenCount = 00 Byte:01B0: InternalSeagateModelNumber = 53 54 33 35 30 30 34 31 38 41 53 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 20 'ST3500418AS ' Byte:01D8: BuildFlags = 00 00 Byte:01D8: Bit:0, QNR_SUPPORTED = 0 Byte:01DA: RealTimeUpdatedFlags = 08 00 Byte:01DA: Bit:3, CONGEN_READ_FROM_MEDIA = 1 Byte:01DC: CongenLastWriteCaller = 00
F3 T>^C
Spinning Down
Spin Down Complete Elapsed Time 6.015 secs Delaying 5000 msec
Jumping to Power On Reset¤ Rst 0x10M SIM Error 1002 (P) SATA Reset
SIM Error 1002 SIM Error 1002 SIM Error 1002 PASS SIM Error 1002 SIM Error 1002 SIM Error 1002WriteDCOInfo FAILED during Initialization RW: Error processing Performance Parameter File: 203C PASS SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 InitiateMarkPendingReallocateRequest for disc_lba: 000F3EB9 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002 SIM Error 1002
Power OFF Power ON
F3 T>^Z ASCII Diag mode Может кто-то прокомментирует, пожалуйста. Что за ошибка LED:000000CC FAddr:0024E4A3
F3 T>^A
ilder ID: AT,
Servo FW Rev: D249
F3 T>/1
F3 1>N1
SIM Error 1002
SIM Error 1002
SIM Error 1002
Init SMART Fail
Rst 0x10M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
ASCII Diag mode
F3 T>^L
73 01
ilder ID: AT,
Servo FW Rev: D249
Features:
- IOEDC enabled
- IOECC enabled
F3 T>
ATA
SATA Global
Link Layer
Transport Layer
400A0290: 0000 0000
NCQ Cmd Validation
Application Layer
Shadow Task File
PhyPM Regs
Physical Layer
400A08A0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08B0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08C0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08D0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08E0: 0000 0000 0000 0000 0000 0000 0000 0000
400A08F0: 0000 0000 0000 0000 0000 7878 7878 0000
SATA Visibility Mux
400A02E0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A02F0: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Layers Diag Mux
400A0EF0: xxxx xxxx xxxx xxxx xxxx xxxx 0000 0000
400A0F00: 0007 0000 0000 0000 0000 0000
TX
8010: 00
RX
MCTL
AFE
8810: 18 05 00 01
SIF
Wrapper
PatGen
D020: 55 55 55 55
CMU
Traverser Regs
FDE Block
F3 T>
Current status 0
F3 T>^U
73 01
ilder ID: AT,
Servo FW Rev: D249
Features:
- IOEDC enabled
- IOECC enabled
F3 T>^U
'027JJ0DTX'
'ST3500418AS '
F3 T>^C
Spinning Down
Spin Down Complete
Delaying 5000 msec
Rst 0x10M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
Power OFF
Power ON
F3 T>/1
F3 1>N1
SIM Error 1002
SIM Error 1002
SIM Error 1002
Init SMART Fail
Power OFF
Power ON
Rst 0x10M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
F3 T>^Z
ASCII Diag mode
Что за ошибка
