1.2.2. Main Power Connector:
The 2 x 10 main power connector has been replaced by a 2 x 12 connector. This was made to
support 75 watt PCI Express*requirements. Pinout assignments are based on the SSI
recommendation.
With the added 12V, 5V, and 3.3V pins the need for an Aux Power connector is no longer
needed and the guidance for this connector has been removed.
главное гнездо питания ето тоже ATX 2.2 :
РЕКОМЕНДУЮ К ПРОЧТЕН
formfactors.org/developer/specs/ATX12V_PSDG_2_2_public_br2.pdf ~350KB
