решил поискатъ решение в нете : 2IVP -игрушка
Unfortunately, it is very difficult to get WH:DO to run under OS versions newer than Windows 98. However, the game runs perfectly well under a Win98 virtual machine running on Windows XP. 3D accelerated graphics, though, will be difficult to achieve unless running a true Win98 OS with an authentic 3dfx Voodoo Graphics card.
It has been reported that WH:DO can be run on post-Win9x operating systems: [1]
First you need to set the program to run in windows 98 compatibility mode. Then you need to make sure you don't use hardware cursor, and you need to force a software renderer. If you try to use a modern 3d card it is flickery.
There have also been reports that reducing the Microsoft Windows hardware acceleration from full may allow the game to run.
2IVP -игрушка не такая старая там и 3д саппорт был...может какнидъ попробую ...
