BP423.EXE 80924IAG.BIN >rep.txt
BIOS Patcher ver. 4.23.
Found 2Mbit BIOS (6.x)!
1. New CPU Support : -> fixed.
2. P3-detect error : is not needed to be fixed.
3. New Koeffs Support : is not needed to be fixed.
4. 32Gb-problem : not found.
5. Some HDD detect-problem : not found.
6. "MB"/"GB" string search : is not needed to be fixed.
9. Error display Freq>999MHz : not found.
10.Error display Koefs>9.5x : not found.
11.New Stepping Support : is not needed to be fixed.
12.Tualatin L2-init error : not found.
13.New Freq in Setup open : found, but Unknown format!
14.Set "Y" as default on exit: not found.
UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
[CPUCODE] ROM is releaseCBROM V2.07 (C)Award Software 2000 All Rights Reserved.
Adding modul.tmp 24.1%
Adding start.tmp 87.5%
Adding cpucode.bin 55.9%
(c)2002-2003 apple_rom, www.ROM.by
13-я строка довольно частое явление.
А вообще для чего патчится? Судя по логу ничего кроме микрокодов не добавляется.
Все прекрасно патчится:
