HAT2168H Drain to source voltage VDSS 30V Gate to source voltage VGSS ±20V Drain currentID 30A Drain peak currentID(pulse) 120A
заменил на IRF8113
Drain-to-Source Voltage30V Gate-to-Source Voltage ± 20 Continuous Drain Current, V @ 10V GS17.2A Continuous Drain Current, V @ 10V GS13.8A Pulsed Drain Current 135A
пока работает, греется средненько.
HAT2168H
Drain currentID 30A
заменил на IRF8113
