Георгий! А плата точно ASUS P2L97 ? a то
Георгий!
a то там есть и ASUS P2L97-DS и ASUS P2L97A и ASUS P2L97-S.... roll
driverstock.com/ASUS-P2L97-driver-download/6-9-3676/index.html
ASUS P2L97 P2L97 BIOS 1009 Fix Microsoft Pre-OS test... driver
P2L97 BIOS 1009
Fix Microsoft Pre-OS test failure.
Support IDE hard disk larger than 32G bytes.
Fix Russian Y2K test program failed.
Revise Y2K patch.
Fix boot failure with some boot managers installed.
Update Symbios BIOS to Rev 4.12.
No system node report for LPT when it is Setup disabled. (LPT disable in Windows when it is Setup disabled)
Upgrade microcode update for Celeron mA0 stepping (CPUID=660) to revision 0A.
Microcode update upgrade for PII 653, 672, and 673. 653: 00A->010; 672: 00B->00C; 673: 007->00A.
Fix serial port failure running Windows 2000.
Add keyboard wakeup item with three choices of key combinations.
Fix FDD Write Protect function failed with (format a: /u) command.
Download link - driverstock.com/ASUS-P2L97-driver-download/6-9-3676-5403/index.html
