ИМХО, это SX с пониженным напряжением питания ядра (Low Power)
Хотя и здесь гугль всем поможет
386SL Definition
Definition of: 386SL A version of the 386SX designed for laptops. ... Except for
memory and video controller, the 386SL and the 82360SL chip made up almost ... www.pcmag.com/encyclopedia_term/ 0,2542,t=386SL&i=37059,00.asp - 80k
386SL
A version of the 386SX designed for laptops. It had built in power management, and its variable clock rate allowed it to idle for long suspend and resume periods. Except for memory and video controller, the 386SL and the 82360SL chip made up almost the entire computer. See x86. computing-dictionary.thefreedictionary.com/386SL
даташит на память:
alldatasheet.co.kr/datasheet-pdf/pdf_kor/107769/MITSUBISHI/M5M44400ATP.html
