they are similar http://www.rom.by/forum/Moshchnye_tranzistory_primenjaemye_v_BP_Podbor_i_zamena?page=12 between pin 1 to
Its not a NCP1203 , its a NCP1200D60
they are similar
ALso the TNY267 has different pins , can it do the job ?
between pin 1 to pin 2 capasitor 0,1uF
Pin 5 instead 8N80C drain
Pin 7 instead 8N80C source
Pin 4 connect to pin 4 optocoupler
