На ту же тему
Example: How to use Epox 8RDA+ onboard LED to display temperatures:
Right click on the MBM icon in your system tray and select 'Settings'
* General (left side of the window) > Basic (right side of the window) >
UNCHECK: Show confirmation request on closing MBM 5
CHECK: When MBM starts open the dashboard as well
Set the following menu option as double click: Settings
Scroll all the way down to 'Enable RD2Pro Support' and make sure it's CHECKED and >
Port '$80' and Sensor 1 is selected underneath
* Temperatures (left side of the window) >
MBM sensor: Sensor1 > Should display Board sensor: WinBond 2 (CPU Temp)
MBM sensor: Sensor2 > Should display Board sensor: WinBond 3 (Case Temp)
Now click on Apply in the lower left side of the window.
На ту же тему
