Автор: Unknown BIOS (не проверено) , 26 июля 2011
Dear All
I am looking for Intel D102GGC2 Mother board bios in bin format
das711
14 лет 7 месяцев назад
could someone provide me the bios in bin format
or kindly help me to convert the .bio file to bin format
From the fact that available - D101GGC
According to the specs, the boards are the same:
• ATI Radeon * Xpress 200 Northbridge
• ATI IXP 450 Southbridge
• 4 Mbit Firmware Hub (FWH)
• SMSC SCH5017
I think if you flash programmer for its BIOS, you may be able to run the BOOT-block and fill in their native firmware. I practice so do not try.
http://downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Probably need a PCI-video card
P.S. Обратный перевод тем же гуглом - просто вынос мозга:-) Интересно как всю эту писанину поймёт англичанин, когда я сам узнать уже не могу )))))
[off]
Not FWH. LPC or universal LPC/FWH.
das711
-->[/off]
das711
Thank you I will try that
das711
I have tried by copying D101GGC bios. Result is no display with Ram Beep
bios Recovery didnt start from boot block
is it possible to edit .bio and make it to .bin format
[off]
[/off]
savely
Download EFI_Unpacker
https://rom.by/files/EFI_unpacker_0_10a.zip
Run
EFI_unpacker.exe GC1087.bio
Take
file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd
Make BIN
many FFs + file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd at end (total file size == size of flash chip).
Flash this BIN.
Run MB in recovery mode and let it try to flash GC1087.bio .
das711
thanks for the support
can you give me little more briefly
i have downloaded efi-unpacker
extracted the "file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd "
how to make bin can you help me on this
[off]
how to make bin
You have flash chip --> read marking --> size of flash chip --> create file (size of file == size of flash chip - size of file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd), which contains 0xFF (by means of WinHex, for example).
copy /b filename__FF + file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd filename_bin
filename_bin - binary image.[/off]
savely
14 лет 6 месяцев назад
Rename
file-AFCCAA0E-E825-441E-A353-157F1E9D8289.free-00.fd to bootblock.bin for simplicity.
Run attached fillfile.exe as
fillfile.exe a.bin N 255, where N = size of flash chip MINUS size of bootblock.bin (dec number)
Make BIN
copy /b a.bin+bootblock.bin TESTBIOS.BIN
Test size of TESTBIOS.BIN - must be equal size of flash chip.
Flash testbios.bin and run in recovery mode.
