From the fact that available - D101GGC According
According to the specs, the boards are the same:
• ATI Radeon * Xpress 200 Northbridge
• ATI IXP 450 Southbridge
• 4 Mbit Firmware Hub (FWH)
• SMSC SCH5017
I think if you flash programmer for its BIOS, you may be able to run the BOOT-block and fill in their native firmware. I practice so do not try.
downloadmirror.intel.com/15113/eng/D101GGC_TechProdSpec.pdf
downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Probably need a PCI-video card
P.S. Обратный перевод тем же гуглом - просто вынос мозга:) Интересно как всю эту писанину поймёт англичанин, когда я сам узнать уже не могу )))))
D101GGC.ZIP 411.83 КБ
