плата в оффисе, я дома, большую фотку надо смогу сделать лиш завра. вот на етой видно все более менее.
Процессор тот что левее выше, ниже и правее ето гпу (нвидия)а броадком - ето сетевуха. thebookyard.com/images/IMAC17LOG18.jpg
еще деталь по поводу нерабочих маков таких:
"...The iMac G5 Repair Extension Program for Video and Power
Issues applies to first generation iMac G5 computers that have
video or power-related issues as a result of a specific
component failure. If your iMac G5 is exhibiting any of the
symptoms listed below and your computer's serial number is
within the noted ranges, your computer may be eligible for
repair, free of charge. If Apple or an Apple Authorized Service
Provider (AASP) determines that your iMac G5 computer is
eligible as part of the program, the repair will be covered by
Apple for up to three years from the original date of purchase
even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
• Scrambled or distorted video
• No video
• No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to
contact Apple or any Apple Authorized Service Provider..."
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program
for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between
approximately September 2004 and June 2005 featuring 17- and 20-inch displays with
1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the
ranges noted below.
Serial Number ranges:
• W8435xxxxxx - W8522xxxxxx
• QP435xxxxxx - QP522xxxxxx
• CK435xxxxxx - CK522xxxxxx
• YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper
band of the ranges listed below. Only first generation iMac G5 computers are affected by
this program.
• No video
• No power
ranges noted below.
this program.
p.s. куда мануал то отправляти?
