Стандартные HPQFlash.exe и rompaq.exe при работе с оригинальным файлом BIOS тоже не перезаписывают последний 15-й банк...
Может быть "затык" в EEPROM или CMOS. Здесь HP DMI Tools, некоторые из них работают...
/? : Show this help message.
--help : Show this help message.
--displayall : Show all data in EEPROM.
--wassettag string : Write Asset Tag to EEPROM
--serialnum string : Write Serial number to EEPROM
--wmodel string : Write Notebook model to EEPROM
--wskunum string : Write SKU number to EEPROM
--wguid number : Write GUID to EEPROM
--wuuid number : Write UUID to EEPROM
--wmacid number : Write MAC address to EEPROM
--wqpflag : Enable QuickPlay flag
--wctolocal string : Write CTO Localization Code to EEprom
--savetofile : Save EEPROM to file-ESCD.DAT
--loadfromfile : Program EEPROM from file-ESCD.DAT
Warning : string/number will be truncated if too long!
Examples :
coescdrw --displayall
coescdrw --wserialnum FW32167883
coescdrw --wmodel Presario X6000
Вот, что могут HPBI103.exe и HPBQ189.exe:
Assets Utility Version 1.02 Copyright (c) 2006 Hewlett-Packard Corporation Usage: HPIB103.EXE [CMD] [TYPE] {string} CMD = READ/WRITE/CHECK/MODIFY/GENERATE (REQUIRED) TYPE = SERIAL/ASSET/MODEL/ID/SKU/SLP/CHANID/WALLPAPER/BURNFLAG (REQUIRED) string = serial number/asset tag/model name/id/sku number/mb serial/channel id/wallpaper/burnflag id... file name/descriptor_state/mgmt_engine_state/... override_status (string parameter is optional if CMD=READ) Example: HPIB103 read serial HPIB103 write model M700 HPIB103 modify asset 6622HVS3P025 HPIB103 read SLP HPIB103 write SLP [ON,OFF] HPIB103 write SKU [sku number] HPIB103 read SKU HPIB103 write CHANID [id] HPIB103 read CHANID HPIB103 write WALLPAPER [wallpaper id] HPIB103 read WALLPAPER HPIB103 write BURNFLAG [Burn flag id] HPIB103 read BURNFLAG HPIB103 generate serial A:\SN.TXTHPBQ189.exe
