Напечатал он мне инструкцию, только что тут нажимать в моем случае?
3A2239
------- CURRENT SETTING --------
Printer mode EPSON ESC/P
Charaster spacing 10cpi
Page length 12 inches
Skip-over-perforation No skip
Shape of zero 0 with slash
Tear off Valid
Auto line feed Depends on I/F
Turn on again to change setting above
while [FONT] button is depressed
Charaster table PC866
while both [FONT] and [PAUSE] buttons are depressed
Auto CR (IBM emulation) Valid
Draft speed High
Input buffer Valid
while [PAUSE] and [PAPERFEED] buttons are depressed.
Then press one of the buttons below within 10 seconds.
[FONT] Auto CR : Valid (sounds twice)/Invalid (once)
[PAPERFEED] Draft speed : High /Normal
[PAUSE] Input buffer : Valid /Invalid
3A2239 ------- CURRENT SETTING -------- Printer mode EPSON ESC/P Charaster spacing 10cpi Page length 12 inches Skip-over-perforation No skip Shape of zero 0 with slash Tear off Valid Auto line feed Depends on I/F ---------------------------------------------------- Turn on again to change setting above while [FONT] button is depressed Charaster table PC866 ------------------------------------------------------ Turn on again to change setting above while both [FONT] and [PAUSE] buttons are depressed Auto CR (IBM emulation) Valid Draft speed High Input buffer Valid ------------------------------------------------------- Turn on again to change setting above while [PAUSE] and [PAPERFEED] buttons are depressed. Then press one of the buttons below within 10 seconds. [FONT] Auto CR : Valid (sounds twice)/Invalid (once) [PAPERFEED] Draft speed : High /Normal [PAUSE] Input buffer : Valid /Invalid
