afudos /i<ROM filename> [/o<save ROM filename>] [/n] [/p[b][n][c]]
[/r<registry_path>] [/s] [/k[N]] [/q] [/h]
/n - don't check ROM ID
/pbnc -
b - Program Boot Block
n - Program NVRAM
c - Destroy System CMOS
/r - registry path to store result of operation
(only for Windows version)
/k - Program all non-critical block only
/kN - Program N'th non-critical block only
(Example: k0/k1/k3 upto k7)
/c - Skip non-critical blocks
/s - leave signature in BIOS
/q - silent execution
/h - print help
/t - Display ROM ID string
/c - Program Main Bios and all Non-critical blocks
/cN - Program Main Bios and N'th Non-critical block
(from c0 up to c7)
/d - Compare ROM file (skips flashing)
/u<filename> -Display ROM ID
If switches doesn't work, then engineer version needed (afudos229ES, for example).
Afudos (Asus version) switches:
