It means I need to type switch
command line key to prevent check BIOS version
It means I need to type switch that is telling flash utility to skip checking BIOS version. Can u tell me what is proper switch for AUDOS.exe for Asus boards? On official AMI AFUDOS (downloaded from ami.com) i got -x switch for this action, but it doesn`t work with asus MOBOs I tried. It accepting only: afudos /iROMfilename.
Any expirienses with ASUS?
P.S. I tried to flash ASUS P5KC BIOS on ASUS P5LD2-X/GBH. (both using same eproms)
