Автор: gastello10 , 15 апреля 2013
Народ нужна помощь
Плата Intel S3000AHLX
Биос грохнулся в результате прошивки.
Сейчас пытаюсь восстановить биос в Recovery Mode (С перемычкой с сидюка) может кто востанавливал уже?
Где звть образ диска с BIOS?
в мануале написано "BIOS recovery can be accomplished from ATAPI-CD. ATAPI-CD image for recovery is created
using El-Torito format image (which is bootable)"
Как в загрузочную область диска запихнуть прошивку ведь прошивка больше образа дискеты 1,44???
помогите.....
gastello10
13 лет 5 месяцев назад
Вот всёже не поленился почитать, не знаю что читал автор...
intel.com/support/motherboards/server/sb/intel%20server%20troubleshooting%...
Troubleshooting Tools & Docs - BIOS Recovery Jumper
Читал вот это
BIOS RECOVERY INSTRUCTIONS
Recovery process can be initiated by setting the recovery jumper (called force recovery)
or invoked because of flash damaged.
A BIOS recovery can be accomplished from ATAPI-CD. ATAPI-CD image for recovery is created
using El-Torito format image (which is bootable).
The recovery media must contain the following image file: FV_MAIN.FV under root directory.
The system should also contain a DOS bootable disk (HD, USB drives or CD, etc.)
which must include the following image files:
1. IFLASH32.EXE
2. *.CAP
3. AUTOEXEC.BAT
The BIOS starts the recovery process by first loading and booting to the recovery
image file (FV_MAIN.FV) on the root directory of the inserted ATAPI-CD.
This process takes place before any video or console is available.
Once the system boots to this recovery image file (FV_MAIN.FV), user should select
booting the DOS disk which contains the above file list. The further process would
load and execute the AUTOEXEC.BAT and the flash update application (IFLASH32.EXE).
IFLASH32.EXE requires the supporting BIOS Capsule image file (*.CAP).
Once the recovery process is complete, it waits for a user to switch the recovery
jumper back to normal operation and restart the system by doing power cycle.
The following steps illustrate the recovery process:
1. Insert recovery media (ATAPI CD) with the FV_MAIN.FV on the root directory.
2. Insert the disk with all the required files (IFLASH32.EXE, AUTOEXEC.BAT, *.CAP).
User could also put all the files in both step 1 and 2 together into one disk
3. Change the recovery mode jumper (BIOS RECV from normal operation to recovery operation.
The details of the jumper can be found in the Board EPS.
4. Power on the board.
5. The BIOS POST screen will appear and display the progress. BIOS continues to
boot to DOS from the media.
6. AUTOEXEC.BAT file is invoked and it will initiate the flash update (IFLASH32.EXE)
with new capsule file (*.CAP). The message will be displayed if flash update succeeds.
If flash update fails, it will be notified to the user.
7. Once the flash update is completed, revert the recovery jumper back to normal operation.
8. Perform the power cycle.
Короче говоря по не выясненным причинам FV_MAIN.FV не стартует, или как то неправильно стартует, вентиляторы перестают шуметь, но монитор не включается.
Есть вероятность что биос запоролся потому что перед прошивкой не были стёрты все логи БИОСА, по этому и не перепрошиваеться.
Есть идея что нужно попробовать прошиться самой старой прошивкой R25, но нигде её найти не могу((((
gastello10
как я понял на экран ничего не выводится - скорее всего только программатор поможет.
Автор так и не написал, флэху пробовали или нет?
Дисковода в серваке нет, USB не подгружаются, работает только CD
mikkey
Попробуйте этот прожечь http://rghost.ru/45354387
Этот пропищит если ось стартанет http://rghost.ru/45354790
mikkey
И что значит не подгружаются?
Флэха бутовая или как? Индикатор есть? Объём какой?
Подробнее писать надо, чтобы не тянуть инфу клещами... :)
[OFF]
что они имеют ввиду под рутом?
Корневая директория диска. Тут можно погадать, какого именно: то ли загрузочного образа, то ли именно CD. Хотя можно положить файл в оба места :).
если же бут-блок не может грузить ось, то это делает FV_MAIN.FV, который и её грузит
Судя по описанию, именно этот случай - bootblock максимально облегчен и обеспечивает только минимальный сервис обращения к образу для восстановления, который в свою очередь обеспечивает инициализацию остального оборудования и загружает ОС.[/OFF]
gastello10
Попробуйте этот прожечь rghost.ru/45354387
Этот пропищит если ось стартанет rghost.ru/45354790
Не помогло, обращается к CD, уходит в ребут, экран не зажёгся, клавиатура не включилась (
gastello10
Подробнее писать надо, чтобы не тянуть инфу клещами...:)
Да же лампочка на флехе не загорается
mikkey
Значит тока прогер поможет
