Tutorial        written        by : GTac01 **        UPDATE:        this tutorial        explain        the 'old'        manual        way to        unlock        xbox harddrives.        You can        now use        homebrew        xbox apps        to easily        unlock        a drive        with 1        button        click.        ConfigMagic        can unlock        harddrives,        but also        newer        versions        of EvolutionX        dashboards        and also        all 4th        generation        modchip        OS'. First        of all        dl the        hdd unlocker        here (xbox-scene.com/tools/tools.php?page=harddrive) Then        connect        your original        hdd to        your xbox,        using        Evox,        get your        hdd password.        (in the        evolutionx        dash go        'system        utils'        then 'backup'        , this        will make        a directory        called        "backup"        on the        C drive        of your        xbox.        "hddinfo.txt"        will contain        the HD        key)  01:23:45:67:89:AB:CD:EF rewrite        it as        followed: 0123456789ABCDEF0123456789ABCDEF01234567 Yeah        delete        the last        zeroes,        and print        it out,        ull need        it. Now you        have to        boot DOS        (Bootdisk). Go here        for a        bootdisk        that works        with Win98-WinXp. Once        downloaded        execute        it, enter        a Floppy        disk in        ur computer. Then        add the        files:        hdunlock.exe,        hdunlock.pas,        hddisabl.exe,        and hdddisabl.pas        to the        bootdisk        just created. Now,        turn off        your computer,        set your        xbox hdd        to SLAVE,        install        your xbox        hdd in        your computer. Turn        on your        computer        with bootdisk        inserted,        and it        will ask        you to        press        a key,        then press        a key,        and you        are in        A:\> Type        in hdunlock        and press        enter it should        say DONE Type        in hddisabl it should        say DONE. Congratulations        you have        unlocked        your xbox        hdd for        formatting. Simple        way to        format        it in        WinXP: Now boot        to windows
How to unlock your Xbox HD on a PC and use it afterwards as HD for your PC (v0.4)
If your        Xbox is        broken        or if        for any        other        reason        you want        to unlock        your Xbox        HD on        your PC        ... you        can use        this method        ... but        you will        still        need the        hdd password.
Once a        drive        is unlocked,        you can        format        and use        it in        a normal        PC **
Once you        have it,        It looks        like this:
01:23:45:67:00:00:00:00
00:00:00:00:00:00:00:00
it will        make that        disk a        boot disk.
Select        your xbox        hdd, and        enter        your hdd        password
Select        oyur xbox        hdd, and        enter        your xbox        hdd password
enter        "MMC"        in RUN
File-->Add/Remove        Snap-in
Click        on ADD
New window        appears        double        click        on Disk        Management
New window,        click        finish
Click        on OK
Click        on Disk        Management(LOCAL)
then right        click        on disk        1 and        select        the first        option
now right        click        on the        right        box next        to the        Disk 1        Box
Then click        on format,        and format        it the        way you        want it,        select        your partition        letter        and your        ready        to go.
p.s. related info: yec.groupee.net/eve/forums/a/cfrm/f/4671009421
