monitor LG W1953TE   no power
voltage  5V  -->  OK
voltage  12V  --> OK
voltage  3.3V --> OK
I need firmware  ( In this monitor there are two flash memories. I need to find the firmware of this monitor to try to record and see if I can fix the defect.)
The voltage at pin 3 of the UC601 (APE8839) located on the video card is at 5V when it should be 1.8v
