Мама Iwill XP333. Качнул последнюю прошивку, обработал BP 6.10, патчение и прошивка прошли без осложнений. Но при запуске не видно строки патчера. Не включился BD, температура проца как была 40 так и осталась. CBROM с ключем /D показывает, что в прошивку новые модули добавлены.
Лог патчера:
BIOS Patcher ver. 6.00.alpha_10. |for Award/Phoenix & AMI bioses| Attention! Advanced qualification is required! Found 2Mbit Award BIOS (6.x)! Found AMD K7-BIOS/platform! 1. New CPU Support : -> fixed. Adding AMDK7NOW! support : -> fixed. 2. XP frequency : -> fixed. 3. New Koeffs Support : is not needed to be fixed. 4. 32Gb-problem : not found. 5. Some HDD detect-problem : not found. 6. "MB"/"GB" string search : is not needed to be fixed. 9. Error display Freq>999MHz : not found. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : is not needed to be fixed. 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. 14.Set "Y" as default on exit: not found. Tweak options addinng: Bus Disconnect Support : -> fixed. Display Features adding : -> fixed. CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding modul.tmp 42.8% CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding start.tmp 87.5% CBROM V2.07 (C)Award Software 2000 All Rights Reserved. Adding tweak.tmp 45.2% if you can`t see all messages - choose 80x50 mode or run with ">report.txt". (c)2002-2004 apple_rom, www.ROM.by
Лог CBROMa:
******** XP1220.BIN BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
0. System BIOS 20000h(128.00K)12111h(72.27K)XPR1220.BIN
1. XGROUP CODE 09C80h(39.12K)06D11h(27.27K)awardext.rom
2. ACPI table 04336h(16.80K)014FAh(5.24K)ACPITBL.BIN
3. YGROUP ROM 02A10h(10.52K)01C4Eh(7.08K)awardeyt.rom
4. GROUP ROM[ 0] 03240h(12.56K)01830h(6.05K)_EN_CODE.BIN
6. Other(4E00:0000) 00E6Eh(3.61K)00653h(1.58K)modul.tmp
7. Other(2D95:0005) 00020h(0.03K)00041h(0.06K)start.tmp
8. OEM7 CODE 01900h(6.25K)00B73h(2.86K)tweak.tmp
Total compress code space = 35000h(212.00K)
Total compressed code size = 1ED23h(123.28K)
Remain compress code space = 162DDh(88.72K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
Похоже на ложное срабатывание автоотката. Попробуйте сделать и прошить безоткатную версию (естественно, приняв меры предосторожности)
Что-то ищем? Google в помощь
Не работает безоткатка. Шил юнифлешем в резервную флешку, прошивка прошла гладко, ребут, темный экран, звуков не издает. Жаль.
Jazz, Blues & Rock'n'Roll фарева!
