имеем:
M/B ProComp BIW1B Slot1/Socket370 +SVGA+Audio AC" 97 Dual Power 2DIMM
пытаюсь пропатчить вот это добро (по-идее авардовский биос):
procomp.com.tw/driver/j2-1.asp?type=biw1b
ser2.procomp.com.tw/download/biwxb160.zip
по ключику /e
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found 4Mbit BIOS! =============================================================================== BIOS-PartName Segm:Offs Compress/Real_Size "Official" name - what`s meanining ------------------------------------------------------------------------------- ===============================================================================
в штатном режиме:
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found 4Mbit BIOS! 1. New CPU Support : not found. 2. P3-detect error : not found. 3. New Koeffs Support : not found. 4. 32Gb-problem : not found. 5. Some HDD detect-problem : not found. 6. "MB"/"GB" string search : not found. 9. Error display Freq>999MHz : not found. 10.Error display Koefs>9.5x : not found. 11.New Stepping Support : Warning! Not found "genu"! 12.Tualatin L2-init error : not found. 13.New Freq in Setup open : not found. 14.Set "Y" as default on exit: not found. UDMA for "big"-HDD on UDMA33_only_MB fix: not found.
методом "научного тыка" отрезал первые 128Кбайт (по 0x30000)
и по ключику /e вижу:
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found 4Mbit BIOS! =============================================================================== BIOS-PartName Segm:Offs Compress/Real_Size "Official" name - what`s meanining ------------------------------------------------------------------------------- BIWXB161.BIN 5000:0000 0001:1773/0002:0000 "original.tmp" - MAIN part awardext.rom 407F:0000 0000:93DC/0000:D9E0 "awardext.rom" - ALT part ACPITBL.BIN 4003:0000 0000:178B/0000:3792 "ACPITBL.bin" - ACPI table AwardBmp.bmp 4002:0000 0000:0282/0000:168C "awardepa.bmp" - EPA picture _EN_CODE.BIN 4029:0000 0000:0EB5/0000:1DD0 "_en_code.bin" - engl-txt Setup i810.vga 4080:0000 0000:56AB/0000:A000 "VGA.rom" - video-BIOS AWDFLASH.EXE 4026:0000 0000:4389/0000:7B99 modul.tmp 4E00:0000 0000:01F2/0000:0E6E "modul.tmp" - BIOS Patcher file start.tmp 2219:0009 0000:001C/0000:0020 cpucode.bin 4001:0000 0000:54FE/0000:9800 "cpucode.bin" - microcodes ------------------------------------------------------------------------------- CPU_microcodes (CPUID/version/type): ------------------------------------------------------------------------------- 06B4>0001/Sock 06B1>001C/Sock 068A>0001/Sock 0686>0008/Sock 0686>0007/Slot 0683>0014/Sock 0683>0013/Slot 0681>0011/Sock 0681>000D/Slot 0673>000E/Slot 0672>0010/Slot 0665>0003/Sock 0660>000A/Slot 0653>0010/Slot 0652>002A/Slot 0651>0040/Slot 0650>0040/Slot 0634>0035/Slot 0633>0034/Slot ===============================================================================
запускаю патчер на этот отрезок в штатном режиме:
BIOS Patcher ver. 4.23. Attention! Advanced qualification is required! Found 4Mbit BIOS! Can`t find "*BBSS*"! error - cant find start.modul!error!
но тем не менее, в этом файлике *BBSS* присутствует, причем не один раз..
вопрос стандартный - куда копать? ![]()
