Здравствуйте ![]()
Имеется карточка GeForce FX5700 AGP 128Mb. С виду вроде целая, но не работает.
nvflash выдает такую информацию
X:\backup\hardware\video\nv\Winflash5.33>nvflash --display NVIDIA Firmware Update Utility (Version 5.33) Adapter: GeForce FX 5700 Ultra (10DE,0341,0000,0000) H:N B:01,AGP,D:00,F:00 The display may go *BLANK* on and off for up to 10 seconds during access to the EEPROM depending on your display adapter and output device. Reading adapter firmware image... Dumping EEPROM image... 0000: 00 00 00 00 4B 37 34 30 30 E9 4C 19 77 CC 56 49 ....K7400.L.w.VI 0010: 44 45 4F 20 0D 00 00 00 3C 01 91 0E 00 00 49 42 DEO ....<.....IB 0020: 4D 20 56 47 41 20 43 6F 6D 70 61 74 00 00 00 00 M VGA Compat.... 0030: 01 00 00 00 B0 10 C6 B0 30 33 2F 30 36 2F 30 34 ........03/06/04 0040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050: E9 24 EE 00 00 00 00 00 7F 40 60 60 00 00 00 00 .$.......@``.... 0060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070: EC D0 50 4D 00 00 00 00 00 00 00 00 00 A0 00 B0 ..PM............ 0080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00A0: 00 00 00 00 00 00 6C 0A 00 00 00 00 00 00 00 00 ......l......... 00B0: 00 00 00 00 A0 19 B6 3B 00 00 00 00 00 00 00 00 .......;........ 00C0: 14 02 37 02 00 00 00 00 00 00 00 00 00 00 00 1C ..7............. 00D0: 00 00 00 00 00 00 00 00 57 05 00 6A 00 00 00 00 ........W..j.... 00E0: 00 00 00 00 6F 82 6F 36 6F 60 E4 E0 00 00 00 00 ....o.o6o`...... 00F0: 00 00 00 00 00 C2 E6 C3 00 00 00 00 AD 00 00 00 ................ X:\backup\hardware\video\nv\Winflash5.33>nvflash --check NVIDIA Firmware Update Utility (Version 5.33) Adapter: GeForce FX 5700 Ultra (10DE,0341,0000,0000) H:N B:01,AGP,D:00,F:00 The display may go *BLANK* on and off for up to 10 seconds during access to the EEPROM depending on your display adapter and output device. Identifying EEPROM... EEPROM ID (20,EF) : Unknown ERROR: Supported EEPROM not found X:\backup\hardware\video\nv\Winflash5.33>nvflash --version NVIDIA Firmware Update Utility (Version 5.33) Adapter: GeForce FX 5700 Ultra (10DE,0341,0000,0000) H:N B:01,AGP,D:00,F:00 The display may go *BLANK* on and off for up to 10 seconds during access to the EEPROM depending on your display adapter and output device. Reading adapter firmware image... Image Size : 0 bytes Version : Unavailable (Invalid) ~CRC32 : 00000000 Chip Name : Unknown Vendor ID : 0000 Device ID : 0000 Subsystem Vendor ID : 0000 Subsystem ID : 0000 Hierarchy ID : None
Попробуйте nvflash, у вас wfflash старая версия. У меня такое было на 6600gt отвал гпу после пропайки все прошилось.
Угу, спасибо за совет, после пропайки ГПУ стало несколько лучше, исчезли глюки с прошивкой, карточка стала включать монитор.
Кстати карточка теперь стала определяться как GeForce FX 5700LE :P
Но... на экране она умеет показывать только разноцветные полосы...
Это на сколько я понял значит что память дохлая?
Память там стоит K4D261638E-TC50...
Может у вас на сайте есть какая-нибудь статейка по взаимозаменяемости микросхем памяти?
вот в Wiki набиваю потихоньку...
Аццкий ромбовод {:€
Память белые полосы.
Цветные полосы лечатся пропайкой(прогревом) процессора, для FX5700 характерная неисправность.
Все хорошо, что хорошо заканчивается и во время
никто вам не даст 100% гарантии что имеено сдохла память. видюха видюхе рознь
